Diesel leak
Diesel leak
Seems to be coming from somewhere under the pump and only really drips when the car leans on the pump side. Checked all filter to pump unions/ diesel feed/ return - Ok. Will find it but wonder whether anyone's got any bright ideas that could save a lot of searching. It's a Bosch pump.
Cheers fellas!
Post by ken newbold »
Could be the seals in the shaft end of the pump. :(
Thanks Ken for your reply - how is it possible to check this?It's impossible to see under there. Pump out I suppose.
I actually bought that re-con Bosch pump off Ebay last year but it sits at my parents' in UK because postage was so high..
Even if I could get it here - what is the fitting process?? I could always 'borrow' the one off the TRD.. :-s
