can someone confirm the bhp of my car?
also I have heard that my car is fitted with a twin choke carb and over halfway down on the accel pedal the second flap opens and lets more air/fuel in? is this correct?
power output on BX19TRS AUTO
You'll probably find what you're looking for under engines on the Citroen DIY site.
http://www.tramontana.co.hu/citroen/
A twin choke carburettor has 2 barrels exch with its own throttle. You're right - the thing will run primarily on the first choke and the second will open only when maximum power is required - ie when the throttle is opened 2/3 or so.
If you remove the air cleaner/hose or whatever from the top of the carb and look straight down it you should see the 2 barrels and at the top the 2 choke flaps. If you open them you will see the two throttles. If you study the linkage you should be able to dtermine what is (or should be) going on.
Commonly the throttle linkage is restricted and this prevents the second choke opening properly. This may be due to something highly technical like too thick a floor mat, or a maladjusted cable or sticky linkages on the carb. Accelerator pedals can break away from the pedal box but this seems to be restricted to diesel engined cars.
There is the carb section of the workshop manual on Bob Smith's site. I think it covers your vehicle.
http://www.rwbsmith.plus.com/citroen2/plip/
- x 94
tim leech
AndersDK
Re: power output on BX19TRS AUTO
Yes, this is correct operation of the carb barrel flaps.1329dturner wrote:also I have heard that my car is fitted with a twin choke carb and over halfway down on the accel pedal the second flap opens and lets more air/fuel in? is this correct?
You should never feel like your BX19 105Bhp is under-powered. The 19 engine power is extremely well suited to the BX size and weight.
Even the 16 engine 90Bhp is well suited for the BX - also in the auto variants.
If you feel your BX19 is becoming weak, then check (replace) the air filter and check the operation of the vacuum pod on the ignition distributor body. For ease of mind its well worth replacing the entire length of the small dia rubber vacuum line running from the carb to the vacuum pod, as its a standard failure this line detoriates well and truly.
