Im new Broken lumpys window motor
BXrunner
Post by BXrunner »
Im new to the forums just wanted to know how can i fix lumpys windows yesterday all good now nout
the main stealer is saying £200+ not on your nelly
cheers
Why not tell us what is wrong with it?
Common problems - wiring breaks where it goes through the pipe into the doors - probably drivers side - wiring f4or both go through it and of course the door is opened more often.
Slow operation is often due to friction between the glass and the guides and seals including the one you would like to rest your arm on if the glass dropped fully. Silicon spray works wonders.
Switches fail - sometimes respond to switch cleaner but a physical clean or replacement is better.
Loads of posts on here if you search.
BXrunner
Lumpy
Post by BXrunner »
Nout works fuse box is good
Post by ken newbold »
Broken wires in door harness or knackered switches.
BXrunner
Window
Post by BXrunner »
ken newbold wrote:Broken wires in door harness or knackered switches.
could be worse think its wire passenger side gone
pulling the wire out
Our Trim Guru
x 13
Post by DLM »
If you haven't gone in there already, check for continuity with a voltmeter at the motor/switch first - it's much easier than pulling/threading wires in VERY limited space...
BXrunner
Lumpys busted windows
Post by BXrunner »
DLM wrote:If you haven't gone in there already, check for continuity with a voltmeter at the motor/switch first - it's much easier than pulling/threading wires in VERY limited space...
Sorted it some numpty been playing cut all the wiring working ok now
charlotte001
windows
Post by charlotte001 »
Cool taken the covering off the doors and found it was the same thing with mine split wires refitted them with plastic covering to protect them
