cant fit my ham radio antenna to lumpy tailgate is plastic
thank you citroen I now have to spend $468 on a new ham radio antenna as the existing one aint gonna fit to lumpy the tail gate is plastic
magmount wont do
magmount wont do
antenna
How do I upload the picture. No the antenna wieghs in excess of 4lbs follow this link it shows the antenna
http://www.wsplc.com/acatalog/Tarheel_H ... ennas.html
It gota go on the tow hitch.
Re: antenna
There's lots of advice you'll find on this Forum; just do a search. I suggest Photobucket, and keep images down to 599 pixels at their widest.BXrunner wrote:How do I upload the picture
- Sir Jim of the Databases
Wow: HF Mobile
I thought at first you were speaking of a VHF whip but that's impressive. Post up a piccy of the installation within the car please. How much power are you running?
I still hold an amateur Licence (G4MEZ) although apart from an occasional chat to an old pal on 2M, I've been QRT for many years now.
Back on topic, you'll be best off mounting that aerial (antenna) on a custom-made bracket attached to the bumper mounts or adapt a towing bracket. I'd worry about that aerial on a tailgate even if it were made of metal
The ideal would be (if they were ever made for a BX) a bull bar on the front. They're ideal for mounting HF whips
Jim
ham antenna
as soon as I've figured out how to get the mount made I'll post a picture. tomorrow I will be posting a picture of lumpy.
I'm only a 2E so 50watts working on the M0 at present
I am assuming you will be using this whilst static, not mobile.
Why not get yourself down a friendly motor caravan dealers and try and "win" a base that they use for their flags? I had one years ago and used it coupled with a SilverRod - simply drive your front wheel over it and plug in - it still uses the car as a ground plane and works well.
Re: plastic
Holy Cow!BXrunner wrote:mobile not static
In that case I would fit a tow bar and then mount a bracket to that.
What? for being into Amateur Radio and Citroens?Philip chidlow wrote: PS I think you are all nuts![]()
My paricular radio-related interest these days is in the vintage stuff with valves in it
Jim
ham antenna
I've got an ailing Yaesu FT101E with valves that needs fixing
I've figured the mount out simply angle iron bolted to the remaining bolt holes not sure where to get 1/4inch steel angle iron plate around 6inches
Re: ham antenna
Go and see one of your local engineering workshops/fabricators and ask if you can have a rummage around in their scrap metal skip. They are very likely to have a suitable off-cut and may even give it to youBXrunner wrote: I've figured the mount out simply angle iron bolted to the remaining bolt holes not sure where to get 1/4inch steel angle iron plate around 6inches
Nah, nothing wrong with it, they never worked properly even when they were newBXrunner wrote:I've got an ailing Yaesu FT101E with valves that needs fixing
Jim
