TZD on viagra
artic-steel
TZD on viagra
Post by artic-steel »
I was working on my TZD estate last Friday when i got called away, It was set to high on the suspension & it's stayed up
It hasn't sunk an inch & it's nearly a week, is this normal?, if not what are the likely causes?
Nah thats pretty normal.
M
Post by M »
Your Acc sphere and Doesuerereweer valve are obviously in rude health then :wink:
ed4ferrets
Yahoo Messenger: ed4ferrets@yahoo.co.uk
Post by ed4ferrets »
Lucky man, mine droops rather rapidly, into a sort of sit up and beg position :wink:
'94 XM 2.1TD Break
'63 Renault Caravelle
Terry Brooks
Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Post by Terry Brooks »
Mines flat on its ar5e within 15 minutes. :oops: :roll:
AndersDK
Post by AndersDK »
Note : it was set on HIGH and left for almost a week.
Not the usual thing as when left in normal drive height.
This is a good tester as it prooves a number of things :
1) the HC's does not leak
2) the doseur does not leak
3) the suspension cylinders does not leak - when pistons fully protruding
4) it does NOT proove ANYthing on the acc sphere, as this is NOT connected when the engine has been shut off for a couple of minutes. BECAUSE the safety/priority valve disconnects the entire suspension system, when the system (i.e. acc sphere) pressure drops below 100bar.
5) if the rear still sinks fast - in NORMAL height - after the above test result prooved - then its the suspension cylinders themselves that leaks too much past their seals.
