i've seen one of these on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting
has anyone tried one and did it work ok ?
SPHERE REMOVAL TOOL
classic2cv
SPHERE REMOVAL TOOL
Citroen BX
Origami in plastic and steel
^^bx>
CitroXim
- Sir Jim of the Databases
To be honest, It may well work for easy spheres but for the really tough ones, I very much doubt it will be up to the job with just one bolt end-on doing the work.. Face it up to some long-resident rear corner spheres and I reckon it'll throw in the towel.
If you're into hydraulic Citroen ownership long-term, sport out and get a proper genuine Pleiades tool. I've seen one of these work where everything else failed on an Activa Balancing Sphere located high up in the rear subframe and obstructed with pipes and other bits and pieces.
A good sphere tool along the lines of the Pleiades tool is not hard to make. The secret is to clamp tightly around the sphere, not up against it as the one in question appears to do.
Jim
classic2cv
Thanks citrojim
i saw these things on sale last year and i thought that they looked as they were badly made copy of a Pleiades tool
Ken
I’ll take you up on your kind offer if that’s ok
The MOT is coming up in the next few weeks and I’ll be changing the spheres as well sorting out some other suspension bits
Ken
Citroen BX
^^bx>
- Our Trim Guru
- BX Digit man!
I've yet to see one of these infamous "pleiades tools" and am now quite intrigued. Could the owner of one of them possibly post a picture of it?
I've used one of these fabricated tools with a pinch bolt a couple of times, and it does seem to clamp the sphere really rather well. Certainly I've pulled as hard as I physically can on a 2' powerbar connected to one (so about 500lb-ft of torque) and it's worked fine.
citroen7
maxgreenwood
acc sphere removal
at my 4th and successful attempt i used a (decent) chain wrench with a 2ft length of pipe from an old garden table umbrella on the end for extra leverage and it didn't seem too hard after nearly pulling my back out trying to use various other wrenches. bit of constent pressure with the right leverage and it was fine.
'90 16TZS (m), White, 86k
Rob_e (UK)
The one pictured on ebay looks a bit like mine, I think I got mine from Andyspares before they became part of GSF. But as others have already pointed out this one doesn't look as good as others and looks like there is a single bolt pushing on the sphere to hold it in place. The one I have has a single bolt at the top end of the handle that tigtens the whole clamp part around the sphere. It also has an additional piece of metal on once side of the clamp as an additional brace to take some of the strain off the join between the clamp and the handle when undoing tight sphere.
Rob
Rob
BX19 GTi 8v 89 227k
Rob_e (UK)
Here is a picture of my sphere tool, as I said I can't remember where it came from now, probably Andyspares. I have never had problems getting spheres undone with it even the rear ones which had already broken one chain wrench trying to get them off.
A larger version of the image is here http://www.theeatons.plus.com/images/sphere_tool_lg.jpg
Rob
Rob
BX19 GTi 8v 89 227k
surrey_man
That looks so easy to make up its a shame i anit in my metal working job no more i could of had 10 a day made easy dammmmmmmmRob_e (UK) wrote:Here is a picture of my sphere tool, as I said I can't remember where it came from now, probably Andyspares. I have never had problems getting spheres undone with it even the rear ones which had already broken one chain wrench trying to get them off.
Rob
Jon MISSING hes BX 17 TZD
and the Smasshed up Escort est
- Our Trim Guru
