16v oil filter
16v oil filter
What make is best? Any tips for a 16v oil change?
Have a look at this link below and see if that helps. I always use the genuine (Purflux) filters.
http://www.autoair.co.uk/Filters.htm
If there is a Motaquip factors near you, they have Purflux filters pretty cheaply as they are owned by PSA. It will come in a Motaquip box though...
x 103
purflux and total quartz 5000. GSF cheapest, both cost a total of £15 combined, go shopping!
DONT try getting clever and fitting HDi filters or V6 filters, they will starve the oil
Me not get clever. Me do it right. Mmm.
AndersDK
Post by AndersDK »
Hi Philip -
Just realised your 16V is in the colour Gris Dolment - same as my recently purchased 16Meteor.
Any idea what the word (or name ?) "Dolment" stands for ?
BTW : the oilfilter is the standard PSA XU oil filter. Use the recommended viscosity of 10W40 on your engine - with the highest API spec you can get.
QUARTZ is a Total oil product - well reputed oil brand now owned by Elf.
I understood it as Dolmen (no 't')
In which case, rather alarmingly:
So I surmise it means stone grey in the end. Or tomb grey - a bit less appealing!
Vanny wrote:purflux and total quartz 5000.
Purflux yes.
But Quartz 5000???
Quartz 7000 would be better, given it's a 10/40 semi.
AndersDK
Post by AndersDK »
Aha ... Thanks Philip. Yes the french word has a "t" added :
English : Dolmen grey
French : Gris Dolment
Scandinavian : Dolmen grå
Makes sense though as a "dolmen stone grey" colour, because that is the overall impression of the colour, when the car is not exposed to direct sunlight.
AndersDK wrote:that is the overall impression of the colour, when the car is not exposed to direct sunlight.
when the car is exposed to direct sunlight it becomes "finely scratched, bit-dented-in-parts and not-as-shiny-as-you-thought grey!!! :lol:
