I need a regulator to fit my 1989 BX19RD if anyone has a spare one please email me, I can pay good money and pick up from the London area! Is a Xantia regulator the same????
Mike.
BX Regulator wanted.
Mike F
kermit the frog
Are you talking about the hydraulic pressure regulator or a window regulator
not sure if you are talking about the hydraulic one
if it is the same as the Xantia but i am sure someone on here will know.
Regards Kermit
Regards Kermit
Mike F
- Our Trim Guru
Be wary of using a Xantia PR - they are fitted in a different orientation to the diesel BX as the drive belt runs off the LHS of the engine, as opposed to the RHS. It may be possible to dismantle the PR and rejig the configuration, but makes the job more, erm... "interesting".
