rear suspension arm kit for tZD estate needed
gazpacho andulus
Post by gazpacho andulus »
Got the arms off and the bearings are shot. what do I need and has anybody got some to sell me?
Last edited by gazpacho andulus on Mon Apr 14, 2008 8:16 pm, edited 1 time in total.
now I'm listening. TZD Estate 1991
Do you need the whole arm? Or just the bearing kits?
gazpacho andulus
I think it's just the kit. I tried Europarts but they didnt seem to have it all in stock. Any ideas chris?
x 103
stuff the kit, the bearings and seals are like £5 all in! plastic tube can be folded, removed and reused later. The bolt is not likley to have any signs of wear is correctly fitted, then either buy a new nut, of rest the nylock. the near £30 for a kit is a bit of a scam really.
/\ what he said.
Although if you do want the kits:
GSF nearly always have them in stock.
ellevie
Forum Treasurer
Post by ellevie »
Vanny wrote:stuff the kit, the bearings and seals are like £5 all in!
That's very good news.
Where can you get them at that price ?
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
x 103
Border Bearings in Sandy way, Deeside, North wales, i think there on engineers road. Thats a standard price as well!
I've discovered recently that the latest citroen parts lists actually gives specs for bearings and sels now so i can typically order the right seals/bearings without having to take the car apart to find dimension.
They can do better rated wheel bearings for less than factors as well. I should think any bearing retailer can sort you out?
mountainmanUK
Post by mountainmanUK »
Vanny wrote:Border Bearings in Sandy way, Deeside, North wales, i think there on engineers road. Thats a standard price as well!
Just a thought mate, but I reckon it would be a useful "sticky" if you could work out a definitive "Repair Kit" comprising the correct spec replacement bearings & seals etc, and post it on the Forum somewhere.
That would make things so much easier for the "less-techinical-minded" amongst us!!
I'm assuming that any "repair kit" would be pretty much standard for all BX models?
Dave
Our Trim Guru
x 13
Post by DLM »
Doc - are these SKF bearings? I did some homework a few years back on the components of the kit only to discover that SKF's main UK stockist at the time (BSL, I think) seemed to take an indecently large profit - everything was more expensive than at GS&F.
Incidentally, in checking that I did mean SKF and not someting else, I came across simplybearings.co.uk as the paid-for link - anyone know what their parices are like (didn't have ref-nos to hand).
BSL are very expensive and very good.
If I have to use SKF bearings I go direct to SKF (handily they have a little outlet in Stonehouse!), but I prefer and always try to use Timken bearings.
It pays to have a look round on online stockists as prices seem to vary on a regular basis across suppliers.
If you're quick enough you can get some right bargains!
Unless you need Timken HM248218's, in which case they're hard to get and bloody expensive... :cry:
ellevie
Forum Treasurer
Post by ellevie »
Thanks for that Vanny. The full kits now seem to be around £40 so that will be a massive saving.
For reference from service.citroen.com,
Bearing od=41mm, id=22mm, w=14.4mm
Seal od=41mm, id=30mm, w=11mm,
Nylock Nut af=24mm, id=16mm, thread=1.5mm, w= 14mm
Measured bearing widths,
SKF 14.4mm
Mapco 14.6mm
Caution: Citroen and SKF use a 1.5mm thread Nut & Bolt whereas Mapco kits use 2mm threads.
BX19TXD 150k K Reg
gazpacho andulus
I asked at Quantock auto supplies in Bristol yesterday and they had the kit for less than 30 pounds .I have to say that the docs suggestion is better :? but I 'm afraid I'm too frightenened to locate and buy the right separates with confidence(neandertall mechanic!)
gazpacho andulus
rear arm bearings etc
Thanks jon. I'll be looking into those bearing part numbers
regards
chris
jwthwaites96
Post by jwthwaites96 »
gazpacho andulus,
this Quantock auto supplies, where in bristol is it? i just looked on yell and could not find it. also do you know if there is a good garage in bristol that i could use to install them that has experience with BX's, just i dont think i have the equipment to do it or the knowledge.
cheers, any help would be great
John
