Twin fan conversion
djoptix
Twin fan conversion
I fancy this for the red BX, extra cooling can't be a bad thing. I've found one on eGhey for £22 from a 205 TD. Would it fit, and is it worth the money if so? (I know you can make anything fit, but I don't want to be fabricating too much stuff really...)
- Our Trim Guru
Though I'm sure the 16v owners will be able to advise better, it all depends on the original rad that the fans were mounted on, and despite PSA commonality,I suspect the 205 fitment may be different to BX fitment.
If the BX TD and 16v rads and fans setup is similar, the Doc will probably have the double-fan set from my old TD for the time being, if not the loom. You might have a better chance there, with an appropriate rad temp sensor.
prm
I think David is right with 205 fan. I seem to remember???, the OD on the blades are greater and are multi- fined.
On your 16V you should have the dual fan mounting plate.
I would try to match both fans from a BX to avoid any misbalance with the throughput of air and the motor mounting should match your existing set-up.
