Fuse box
TheBig-D
Fuse box
Post by TheBig-D »
Has any1 got a piccy and the layout of what fuse is for what for my '92 TGD BX..
Like you get in a haynes manual.
Thanks in advance.. :D
Our Trim Guru
x 13
Post by DLM »
Suggest you go to the excellent BX DIY website - the fuses summary is here:
http://www.tramontana.co.hu/citroen/electric/fuses.php
As your car is a series II BX use the extreme right-hand column.
Fuses are numbered left to right 1 to 14, though you will only find fuse 14 in use on an ABS-equipped car. Some Haynes sections are available through www.citroenz.com (though the Haynes BOL isn't brilliant on things electric for the BX).
If the car came with the A5-sized owner's guide, then there's a fuse summary there too.
