http://www.trademe.co.nz/Trade-Me-Motor ... 12.htm?p=2
Your citroen's hydraulic fluid, LHM, resembles an intense 'neon' green.
The dish in the foreground shows old and contaminated LHM extracted form a recently purchased Citroen CX. Another picture shows the corrosion it caused to this car's hydraulic reservoir.
During the course of time your Citroen's hydraulic system gets contaminated with gunge, minute particles of metal, water, rubber........, LHM eventually looses its effect as a lubricant and mechanical components such as valves, pumps, etc. wear out before time.
Citroen recommends the use of 'Total' Hydraurincage to clean your car's entire hydraulic systems of accumulated dirt and deposits. It may be used full strength for full effect, or mixed with LHM already in your car.
It can be left in the system for as long as 5,000 km before it needs to be drained and replaced with fresh LHM.
Remember to change the LHM every 30,000 km! I can list 2L quantities of Hydraurincage but fluid will be in 'plain' containers
So erm anyone heard or used this stuff before?
