A long shot but I thought someone might know!
Is a service kit that says it's for BX16 RS/TRS, BX19RS/TRS with Solex 32/34 Z1 carburettor going to be compatible with the carb on my '91 16 TGS with the B2C engine?
The very useful document here says that the 171B, 171C and B2C engines all have the 32/34 Z1 carb, but with different ident numbers (13279, 13543, 13928) and slightly differing specs - but I don't know if that affects the gaskets etc.
Thanks!
Mark.
Carby service kit
mnde
- Meteor Man
- Our Trim Guru
AndersDK
Years ago I purchased both a Weber and a Solex repair kit. Thes kits had a large selection of gaskets, O-rings and bits covering all thinkable carb variants within the family of carbs its made for.jeremy wrote:Gasket kits usually have a few bits surplus. The variations are probably jet sizes and things like anti-stall valves for automatics - the gasket kit will probably cover all carbs in a range.
Its not practical to list all car models/variants these kits may fit, as it would be a huge list filling out a book to cover all possible models over the years ...
You can get these kits for both single and dual barrel carbs.
Note that NOT all kits may contain a needle float valve, which is a very important service part. Check it with your dealer.
