Got hold of a cheap '92 BX 1.9 TGD
After buying insurance at £1000+
What a car i thought with all the mod cons. Central locking, Leccy windows, Hydrolics the works..
Second week of owning it.... It caught fire..
The pack of wires leading to the pass side rear light cluster had melted & caught fire.. Causing the boot carpit to catch fire.. Good job i was carrying a fire extigusher.
A few hours later me & a mechanic friend rewired it.. It dont look pretty but it all works.
That was that problem sorted.
Then.....
The drivers door dropped without anywarning it just dropped. On closer inspection the door hindge was rotten..
Then....
Just last week i got in it to got to work and it wouldn't start..
No matter how many turns on the glow plugs it just would not fire. Called upon my 'friend' again and he advised me to run a live wire to the glow plugs for a few secs. Then hay-presto she started so we knew it was a problem with the glowplugs. £14 lighter all four where changed along with the spill off pipes which were perished and leaking diesel..
At the moment all seems to be fine. The bx has been a pain in the arse but i'll never get rid of it. It's kinda attached to me now.
Only one small thing is it's leaking oil from the rocker cover gasket.
It's also coverd over 200k...
But i love it.
