Engine No. EJXGS / 0120704V
141000 miles
New timing belts at 47k, 84k &127k (1997,2001 & 2004)
No record of new water pump but coolant changed yearly by previous owners and no rust in coolant or radiator.
Three weeks in and all was rosey, she charmed all before her despite the kids warnings of social exclusion. An amazingly real 55-60 mpg in the SE and that smooth ride closed all arguments with the disbelievers, I 'm sure its all been said before, but this is the only car since our mini days that people actually smile at as we float by (VVV rare in London).
But right now she's up on axle stands.javascript:emoticon(':oops:')
Started up this morning, but coolant level light stayed on until moved off inclined drive to level road. No sign of any leaks so assumed just the sensor because of the slope. Short trip of 20 miles and leaking water from rear of the engine but no warning light. Left to cool and put on stands, started up and no leaks until after @10 minutes idling. Water is leaking from the water pump area. Once the engine stops the leak ceases.
Before I tread the path of no retrns with Eurocarparts, G&S etc.. for new water pump and timing belt etc.. is there anything I need to check or investigate before.
I am now of course forced to explain why my carefully selected new car is, after three weeks, off the road and watering the garden.
Would somebody please tell me what I should expect to pay for fitting and how long should it take a competent garage, versed in these cars. Thanks
