steering column rubber coupling
maxgreenwood
Post by maxgreenwood »
a garage here identified my steering column rubber coupling is cracked/perished - i've looked in haynes no joy and searched on here for advice, is it a tricky job and would it be the following part from gsf i'd need?..
N43070 STEERING COUPLING DISC BX UNIVERSAL STEERING COUPLING (+/- PAS) £10.00
'90 16TZS (m), White, 86k
There is info in the Haynes blue book starting page 11*16 but a little interpretation is needed. A fiddly but do-able job which requires working both in the drivers footwell and under the car (Axle stands!) and patience with the spanners/sockets.
One thing though, don't buy just the rubber bit from GSF it's all but impossible to use. Buy the assembled disc from Citroen and this will facilitate saving you scratching your hair out.
maxgreenwood
mmm.. that will be the haynes i don't have then.. i have the dark blue one for diesel engines and the brown one up to 1991?
Our Trim Guru
x 13
Post by DLM »
I think the info is in the older (and to my my mind better )Brown Haynes as well (the petrol models manua), but couldn't swear to it. If I do identify it then I'll come back and quote page numbers.
Unfortunately, not a job you can put off....and my secondhand knowledge from someone else who's done the job is that Waytogo's advice is spot on.
maxgreenwood
mmm.. hope it lasts my trip up to northern ireland and back - meeting with Citroen7 this weekend for some other DIY jobs but can't get the full steering part from citroen until next week. Theres no play in the steering.
Would i be able to take one from another car?
citroen7
Post by citroen7 »
max i am sure there will be something tucked away in the spares department so dont panic !
maxgreenwood
coming from a man with 5 Bxs my mind is eased :)
