Spark plug struggle!!
fatgeezer
- Location: Eastbourne - where we dont bury the dead,we stand them up at bus stops!!
Trying to change the plugs on my St. Tropez - but have fallen at the first hurdle. The leads dont want to budge - is it a case of brute force and ignorance or is there a knack? Also are the plugs that deep that I will need a special tool when I do find them?. I have found a plug socket deep in the bowels of my rather skimpy tool box that fits on the plug as they are smaller than 'conventional' plugs. I thought this would be a nice easy job - wrong!!.
1990 BX 14 St. Tropez
1996 Citroen Synergie 1.9 td
1989 Mercedes 300se
1989 Mercedes 300se
- x 117
Just grip the plug connectors part way down with some adjustable pipe grips or similar so as not to crush them and go for it.
You need a 16mm deep socket for the plugs, nothing special.
fatgeezer
H546 AKR
Thanks for the above - it may have seemed a stupid question to ask - but I did'nt want to get too butch with the leads in case something broke (par for the course!!). Job done - new Bosch plugs in now to replace the old NGK's which by the way looked OK with a light coloured coating on the electrodes but had a strong smell of petrol. Is this normal?. I have only taken her round the block but she seems to run better now. I was getting a problem with her getting 'bogged down' when pulling away and having to give more revs or slip the clutch slightly to avoid a stall. Air filter next!!. Thanks again.
1989 Mercedes 300se
1989 Mercedes 300se
