central locking problem
macker37
Having recently purchased my latest 16v on H reg noticed central locking not working. All doors open if operated from passenger door. Having looked at loom in door and seen strawberries no really appears all wires to it are green and have been broken (by previous owner) dunno which to connect back together , any ideas appreciated.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
i've found a few cars that will operate central locking from the passenger side when they have the plip. I know some two of these have been 'modified' (one ofwhich is my own) but the others where standard. There is no difference in the physical loom as the plip loom is a plug in and so the wires and connectors are inplace to add a full locking unit to the passenger side. Anways as with all things French, just because most of them dont do something from the factory doesn't mean there all that way. Clearly a none full CL on the passenger side is a cost cutting exercise!
