brakes
marthter
brakes
hi im a newby im also dislectic so bare with the spelimg please can anny one tell me wher the brake top up reservar is on a bx 1.9 deasel as i cant find it anywere and wont to change the brake pads i have the haynes manual but no can find bx is a manual cearbox thanks
1.9 diesel bx in dark gray colour body work is in excellent shape and never had any work done
Hi There,
The brakes are powered by the hydraulic system, as is the suspension and power steering (where fitted), the reservoir for the hydraulic fluid (LHM) is found at the front of the engine bay on the drivers side. LHM is readily availabe from most motorfactors or Citroen themselves if you have money to burn.
Good luck with the pad change.
marthter
brakes reply
thanks for the reply it had me going raond in cicles trying to figer it out i thought it only workede the suspention thanks again
- BX Digit man!
