Car won't start
Car won't start
Hmmm, tried jump starting the car yesterday after not having used her for 2wks. The central locking didnt operate so battery was flat. The dash lights came on, interior light & the glow plug relay made the usual dull thud sound when the jump leads were connected up. But when turning the ignition key, the engine did turn but very slowly & as though there was no real juice getting to the right parts.
Any ideas on what i might need to check, it might be that the battery has got a duff cell, but rather than messing about battery swapping there might be something simpler?
Its my 19TXD by the way.
CitroXim
Sir Jim of the Databases
Post by CitroXim »
Might be just a bad earth Mulley. The one down on the gearbox is always a favourite.
Jim
Hi Jim,
can you describe whereabouts it is please? I've had a look at Haynes & couldnt find any picture of what & where i'm supposed to be looking for.
demag
Post by demag »
Are the battery terminals tight? Might be worth undoing them and give everything a clean up with wire brush/emery paper. Its possible for the posts to oxidise and give a bad contact. Was the battery ok when last used?
Dave.
1990 Bx TGS automatic.
CitroXim
Post by CitroXim »
MULLEY wrote: can you describe whereabouts it is please?
If you follow the thick -ve (earth) lead from the battery terminal it will eventually end up bolted to the gearbox housing. Off times it's bolted direct to a threaded boss on the top of the 'box in the vicinity of the top selector arm and at other times it's bolted to the side of the PAS pump cradle on cars equipped with the cam driven PAS pump.
Jim
Car is negative earth - so follow the negative battery lead - which in fact probably goes to the engine or gearbox. Somewhere there should be another lead linking the power unit to the body. For starting purposes the earth to the engine is probably enough. You can check it by connecting the NEGATIVE jump lead to the engine itself - thus bypassing the lead and its connections.
If the car battery is really flat - you won't start the car with jump leads straight away. Connect up the leads and run the supply vehicle at a fast idle for about 10 minutes to get some charge in the vehicles battery - then with the supply vehicle still running fast try and start your car. If the motor is still slow - leave it a bit longer to charge.
You'll find the supply vehicle's revs drop quite a bit with the additional battery load - this is what should happen.
If you're using puny cheapo jump leads - forget it altogether.
Better to remove your car battery and charge it for the appropriate time (ie overnight on a 5 or more amp charger) then re-fit it and try again.
Self contained Jump starts won't be enough if the vehicle battery is flat. (unless they're the huge commercial vehicle type)
Deemag, as far as i'm aware they are tight, i'll double check. Battery seemed fine before the layup. If the posts oxidise, dont they go a whiteish colour? If so, then it cant be that as theres no white residue.
Jim, i'll have a gander tomorrow when there's some light. I presume the contact area just needs a clean-up to sort the earthing issue?
Cheers guys, will report back tomorrow on whether its solved....
x 103
doesn't sound like the earth, sounds like a stuffed battery. Buy a new one. THeres clearly not enough current as the batterys sucking it up.
mnde
Meteor Man
Post by mnde »
There's a good remedy for this problem - always remember to unhook the battery if you're going to lay up the car for a couple of weeks. I tend to forget and it's really annoying to get in the car, turn the key and -click- wuh- wuuuuh- wuuuuuuuuuuuuuuuuuuuuur :oops:
That reminds me I wanted to look and see if there was a switch I could buy to mount on the battery so you can quickly disconnect it from the circuit without having to touch the leads...
Cheers,
Mark.
mike st gilles
Post by mike st gilles »
Another way to stop this happening is to use one of those solar type trickle chargers (as long as the car's in the open that is). I use one of these in France on my BX that lives there...... Car always fires straight up even when left for 4 months.
You don't even have to leave it on the outside of the car as it seems to charge quite well enough sitting on the top of the dash plugged into the cigar lighter (tbh you could put the other set of leads that come with it which have croc clips attached and lead it straight on to the battery).
I think they're about a tenner from most good acc shops (and some bad ones as well lol)
This always assumes that the battery is a good one in the first place....
Mike
jonathan_dyane
Post by jonathan_dyane »
Cheers,
Mark.
This is just the thing you're looking for. Obviously you would want to fit it without the fusible link...
Thanks for the help on this chaps, i changed the battery from one of my other cars & it starts fine. I'll try charging the offending battery up to see if its salvageable.
Do you have a radio in the car? If so does it turn off when the key is removed?
BX ones generally don't as they were built when cassette tapes would tangle if a player was stopped and started - as when starting the car.
This arrangement is fine if the radio has a proper mechanical on/off switch - ie one that goes click.
More modern units tend to have electronic switches - which are fine but they leave the unit taking a substantial standby current. This is no problem if the vehicle wiring disconnects the unit when the key is removed (or in the off position) but as the BX is wired without this position they will continue to draw this current and flatten the battery after a few days.
Cure: - a separate on/off master switch is probably the easiest - or remove the power (not memory) fuse, or re-wire to a supply switched by the key - with a relay?
Yup, it was the cd player that ran the battery down, its permanetly on standby, quite irritating. And of course i cant remember the bleedin code to get any tunes out of it. The code is on the top-plate of the unit, but i couldnt get it out, so i'll have to get my friend help.
I'm sure i've seen a device that fits onto the battery which auto cuts off the power if the battery voltage falls below a certain level. However, i think the easiest approach of disconnecting the battery is the easiest & the cheapest.
Your CD player needs 2 power supplies - 1 for its memory and the other for power.
Find the power lead and extend it and fit an on/off switch on the console between the seats or some where else convenient like above the heater controls
I was going to do this for my CD player - till the one in my wife's ZX went wrong. She's now got the CD player and I've got the old radio/cassette back in the BX. Still it does have long wave so I can listen to the cricket.
