So have any of you guys heard about this?
Apparently the BX19TRI was mainly aimed at the New Zealand/Australia Market (probably why never heard about them until recently) and with that in mind can run on our most commonly used (cheap) Fuel grade.
As far as I was aware the lowest grade of Fuel a BX could Run is 95 Octane (Your Unleaded Grade in the UK). So what you reckn in trusth in the idea that 91 can be used in a 19TRI?
BX 19TRI running on 91 Octane Fuel
1990 BX19 TZS Auto 06/11/1989
