Where to get hyfro pipes and rear arm bearings?
djoptix
Post by djoptix »
Next on list for the track BX - full set of coated pipes and rear arm bearings. Where can I get them?
djoptix
Post by djoptix »
Arse, I meant hydro! Come back edit button!
x 103
coated in what? If you just want plastic coated pipes, call Citroen, there not too expensive!
If you want pipes that are going to last then you want kunifer pipes, you could get them from Bonapart 2CV in chester but you'll need the tooling to make the pipes up!
djoptix
Post by djoptix »
Plastic coated ones FTW, I can't be doing with bending pipes. I was going to do the whole pipe-flaring kit etc but I need to do all the long pipes and I just don't have time. Main stealer it is then, thanks Vanny. How about rear arm bearings? I thought I could get this stuff from GSF but it's not on their online catalogue any more, it seems.
demag
Post by demag »
Noticed last night on ebay. There are loads of pre made pipes for sale. :D
Dave.
1990 Bx TGS automatic.
