Tappets? - 16v video
djoptix
Post by djoptix »
I've uploaded a video of my 16v idling. It's doing some clicking which I'm a bit suspicious of. My thought is - oil spray bar across the cams is blocked, meaning noisy tappets. Your thoughts? Is it serious?
Excuse the chicken;
click here
My 16v is a little bit tappety and I know Kitch said his was, the hydraulic tappets get gunged up and stick, they do an additive which apparently will help "ungum" them, I tried it and it made no difference.
Sometimes a oil change and a damn good thrash may help?
djoptix
Post by djoptix »
Maybe after the cambelt is changed...
Or you could fit a devil link pipe instead of the middle box like mine then you can heard the engine over the sounds of the exhaust :shock:
djoptix
Post by djoptix »
I forgot to bid on it :( :lol:
Rev. Dick Deluxe
Post by Rev. Dick Deluxe »
The only way to cure noisey tappets is to take them apart and clean them.
Its not a difficult job once youve got the cams out, its just boring, but the difference it will make is well worthwhile.
Blocked oil spray bar wont cause noisey tappets but it will cause your cams to wear out which can sound the same as tappets only more expensive to fix.
Would it be worthwhile, do you think, to replace the tappets once you have them out? The reason I ask is that if they have worn to any great degree, I wonder if they may not 'pump up' as well as they should, especially with warm oil.
Have you removed the valves recently by chance? Or has this just started by itself recently?
If so, then stripped and re-dressing them is the way forward. I got a how-to off the 205 GTi drivers site which I can email on to you if you want?
Mine's tapping because if you don't bolt the cam bolts back in exactly in the right sequence, some of the valves kiss each other on the way down which puts them out of shape and makes them slam, or tap, shut! Mine's been doing it for ages now after I ballsed the engine up. I overhauled the tappets, the top end felt tighter and quieter....but the single tap remained :(
Rev. Dick Deluxe
mat_fenwick wrote:Would it be worthwhile, do you think, to replace the tappets once you have them out? The reason I ask is that if they have worn to any great degree, I wonder if they may not 'pump up' as well as they should, especially with warm oil.
They shouldnt need replacing, the problem isnt wear but more a build up of carbon inside the tappet causing them to stick and blocking up the oil feed holes. They'll actually pump up better with warm oil as its thinner and can flow easier. Thats why they can be rattly when you start a cold engine but get quieter as the engine warms up.
Ah, I have the opposite problem on my VW van. Occasionally when the oil is hot they will clatter for say 30 seconds, and then settle back down again. Anyway, I won't hijack this thread - last time I asked a technical question about the van it went off at a tangent, things started getting heated and the thread ended up being locked!
