After battling some electrical gremlins I'm reasonably sure that I'll need a new alternator for my aircon-equipped turbodiesel. Does anyone have any recommendations for spec and supply in the UK?
Despite a comprehensive clean-up of known trouble spots I have no alternator light illumination - just the faintest glimmer, and no charging taking place. Alternator leads are OK from the resistance/continuity point of view, alternator connections have been cleaned/checked, the brown 7-way block next to the battery has been given a thorough clean, and the panel bulb itself checked/substituted.
I'll probably sub in a spare 19D alternator in the short term, which should also provide confirmation of whether the alternator is at fault.
Alternator for Turbodiesel with aircon - suggestions?
- Our Trim Guru
- Our Trim Guru
ed4ferrets
- Yahoo Messenger: ed4ferrets@yahoo.co.uk
I have a 70ah alternator you are welcome to, surprisingly it came off a 19d, are they not usually 50ah? Known to be working when removed and will need pulley change. Any time you're down this way David
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
- Our Trim Guru
- x 117
You can use the standard 50a on an aircon BX. Cit did fit the 80a on these as OE but this is not really required. You only use the higher output when the car is in traffic or ticking over with the aircon and consequently both fans running, i.e. not very often and certainly not enough to drain the battery.
The higher output alternator is the same size and uses the same fittings as the 50a, so no worries there should you decide to spend the extra ££s and fit one. They do cost a lot more though.
- Our Trim Guru
Thanks all - will stick with the 50A for now. A French trip for which repl alt had become a necessity was postponed as still had a lack of charge, possibly because I was fitting it in less than ideal conditions (heavy rain, outside). Alt was OK after checkover by Tom, new charge wire, and attention to all connections for absolute cleanliness. Relief!
