Water pooling in passanger sill
maxgreenwood
Post by maxgreenwood »
I need to sort the surface rust thats starting in my passanger door sill seams. Theres water pooling there from running down the rubber door seal when its raining.. could this be because the door is drooping a bit and is squashing the rubber at the bottom and not letting water drain away?
Just wondered if this was a common problem.
'90 16TZS (m), White, 86k
