Foglights
Foglights
Are these the right size? if so look like a bargain, might get a deal if a few interested parties club together, as there are 5pairs available.
http://cgi.ebay.co.uk/Citroen-BX-Fog-Li ... 286.c0.m14
They're taller and narrower than than the usual fog lights, but yes they will fit.
Although if I wanted to upgrade from fog's to driving lamps (which are legal for road use unlike these) then I'd get the rather good Cibie or Ring units from any number of UK stockists for not many pennies.
As it goes the TD has driving lamps, I might use them once a year maybe...
Toddman
Post by Toddman »
docchevron1472 wrote:Although if I wanted to upgrade from fog's to driving lamps
I could be wrong mate but I seem to think the AX had the same lamps as the BX and they were driving rather than fog so should just be a case of swapping the glass over ?
Luke
Please call me Luke :)
http://www.bx16valve.com
You are quite correct Luke.
Infact Pug 405 Mi's had both IIRC.
Although they look the same bar the glass the bulbs and the reflectors are different, so you'd need the whole unit.
Actually thats not a bad idea, I put ring units on the TD, but it would look rather better with proper OE spec lights, ta for the reminder mate!
