Hi Guy's, I am hoping you guy's might be able to advise me, a fellow BXer and myself have just installed a new second hand HP pump on my 1.9 diesel. Started it up and it works but it is noisey, I am guessing it should be quet but I kind of hoping its not ment to be, something along the lines of diesels being noisey so the HP pump are noisey.
Any help is always appreciated.
J
New second hand hydralic pump - not so great
jwthwaites96
jonathan_dyane
Aerodynamica
If you just installed it there can be air in it. Did you prime the pump with LHM before connecting it all up? also once installed, you do the old trick of running it with the bleed bolt of the pressure regulator open then tighten it until the reg cuts out and then open it a gain- repaet this for a minute or so to purge all the air out the regulator and pump.
I had a loud new pump on the CX a few months ago due to not priming properly - primed, restarted and suddenly all was quiet...
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
jwthwaites96
Hi Guy's, cheers for all the usggestions.
well as for the noise, i'm not sure how best to discribe it, possibly a ticking, it sounds like the bearing is just banging around, I think its rythmic.
The bleed screw thing, do you bleed it till lhm comes out of the bleed?
The belt was slipping but that is all tight now, so thats not the problem.
J
J
Aerodynamica
! no don't remove it or anything!The bleed screw thing, do you bleed it till lhm comes out of the bleed?
Sorry I should have been clearer - With a 12mm spanner, all you do is loosen the bolt on the pressure regulator body by no more than 1/2 turn. If the engine is switched off and you then do this you'd hear a sudden localised whoosh sound as the accumulator dumps its contents. With the engine running, loosen this by half turn and wait a few seconds then retighten and wait until you hear the regulator click, repeat a few times - no fluid should come out anywhere - you're bleeding the LHM back to the tank. Some say this procedure should be done with the suspension at high setting but I can't see why it makes a difference. This job is dealing only with the HP pump, regulator/accumulator and the LHM tank.
It was a regular rhythmic ticking my pump was giving too - it suddenly vanished after bleeding.
Having said that it -MIGHT- be caused by a bad pump but you can eliminate it by bleeding the regulator.
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
- Our Trim Guru
If you've got air in the pump - not unusual after a refit or reconnection , then it'll probably be rattling like a bag of nails. Exactly how big a bag of nails, and how many nails depends on the amount of air and where it is.
Cure as per Aerodynamica's post.
jwthwaites96
hi Guys,
well we have tried doing the bleeding you mentioned but it is still clunking, now at this point i would say its knackered but the thing that makes me think that there is still hope is that the power streering works great but when driving and doing a right hand corner it gets really heavy, would this be due to air being in the system?
Aerodynamica
jwthwaites96
