My car drives beautifully ride-wise when 1st started up, ie engine cold, for about 5 or 10 minutes, glides along, absorbs all speed bumps and holes in the road. Just like i think a citroen should. I'm always really into the car at this point. Then the suspension stiffens up and the car kinda gets shaky - not drastically so, but especially on some surfaces the car shakes up and down. And the road makes the interior fittings shake and crack a bit. Not at all like it should be i don't think. And i'm thinking 'this can't be right' It starts to happen exaclty when the engine has warmed up and is idling at 900rpm as opposed to the advance 1,100 or so. The wheels are balanced. The tracking is not quite right but this doesn't explain these differences i don't think.
I mentioned this before on here and was given some good advice from jeremy to grease up the height correctors, which i did, and got some imrovement, but i'm not sure i've done it properly. Do i need to remove the plastic cover and get right in there? How do i do this? I found it very difficult to even see and just kinda squirted grease around it. I would appreciate any extra advice on the best way to get in there.
Some details about the car:
The car has just completed 2000 miles on Hydraflush, taken out and filtered twice in this time as steering was getting heavy and a load of silt was collecting. I'm due to change back to new LHM soon. I've greased the front struts under the gaiters and this makes it very smooth to rise and fall. Tick time is 10-14secs. Acc sphere+front sphere 10 months old, rear spheres a year old. So i think they're all good. Nice and soft when car pushed on corners after its been left for a while engine off. (although much stiffer straight after a run concurrent with symptoms described above)???
It feels like its is stiffening up at the rear as well as the front, so i don't think it is primarily front strut related.
If the ride is great when cold, stiff when warmed up
Please help me Obi Wan CLub.co.uk you're my only hope
