Just lately ive been having a problem with the hydraulic system on the red 16v. When the system pressurises ( ie when it ticks ) it somehow is stalling the pump causing the engine to almost stall and it only hapens every time it ticks. It was sugested the pressure regulater may be faulty so i bought a recon one from plaedies which has bought the tick time to around 40 seconds from around 10 seconds but the problem still exists. Could it be a problem with the flow valve (fdv) or the pump its self which was renewed 18,000 miles ago. Im worried now because it puts such a strain on the engine it coud snap the camshaft or cambelt at any time.
Any help will be greatly appreciated
cheers rob
suspension hydraulics
rob-bx16v
bx16v p2 k reg red
bx16v p2 j reg green
bx gti 8v h reg blue
escort rs turbo g reg red
bx16v p2 k reg red
rob-bx16v
I fogot to mention it only starts doing this when the car has been run from cold or standing a while after about 2 minutes of ticking over. Ie once theres pressure built up in the system.
bx16v p2 k reg red
bx16v p2 k reg red
Aerodynamica
rob-bx16v
way2go, the co should be fine as it was adjusted for the last mot although it does hunt a little bit when cold. I also replaced the idle control valve thinking it could be lazy but the problem still persists.
. out of all the bx,s i have owned over the years this is the only one that has had this fault and its driving me mad
[/quote]
bx16v p2 k reg red
bx16v p2 k reg red
