HUGE BX PARTS CLEAROUT
No not me, but a mate of mine through the SD1 Club works for a Citroen Dealer up in Lincolnshire, and Ive been asking him for a while if they had any BX stuff!
Anyway it turns out they have a stock of MK1 and Mk2 Parts and have emailed me a 43 page long list today asking for"offers" to get them gone. Each part has a part no which is handy.
Im not good with computers, this list has been sent as a word doc, I have copied and pasted what I can, I am awaiting a name and no or email, I can forward you the email if you wish if you cant read the list properly.
Please contact them directly regarding parts.
Suspension & steering
Part number Qty Description Application RP No> >RP No RRP
96070144 1 LHF wishbone 208.63
96070145 1 RHF wishbone 208.63
95611436 1 Wishbone spindle 23.87
95637690 4 Front wishbone front bush 12.15ea
96070064 4 Front wishbone rear bush 16.36ea
95615973 1 LHF hub carrier/swivel ABS 357.08
370142 1 Rear hub & bearing Non-ABS 108.48
95035532 1 Rear hub & bearing ABS 116.24
95571695 1 LHR suspension arm Non-ABS 283.29
95637694 1 Front anti-roll bar 1.6 petrol, 1.7D, 1.9D 55.33
95597955 3 Front anti-roll bar link 3857 66.36ea
95630094 1 Steering flexible coupling PAS 21.99
95631286 1 Steering flexible coupling Non-PAS 17.74
95496044 1 LH track rod end 72.06
95495440 1 Inner steering ball joint 50.35
405825 3 Inner steering joint lock washer 1.38ea
95604346 1 Steering rack gaiter LH? 22.57
95496072 1 Steering rack gaiter RH? 10.73
406621 1 Steering rack protector RH? 4.96
95496583 1 Road wheel 5x14, non-vented 61.68
540163 1 Road wheel 5x14, vented 32.41
96155310 1 Road wheel 5.5x14, vented 38.65
Hydraulics
95599871 1 Rear suspension cylinder Estate 109.98
527207 1 Cylinder stop plate 7.25
527209 4 Pushrod retaining clip 1.13ea
527210 4 Stop plate retaining clip 1.89ea
95568737 1 Rear suspension pushrod 42.51
529122 1 Front height corrector 104.54
4048G2 1 Steering pinion valve PAS 338.37
96151895 1 Security valve 73.50
402401 1 Flow divider PAS 632.55
5491085 1 LHM reservoir 99.84
527108 1 LHM reservoir level sensor 9.31
95488446 1 LHM reservoir cap 5.53
5508681 1 LHM reservoir filter 18.45
527106 2 LHM reservoir filter 7.39ea
5461317 1 LHM reservoir retainer 13.08
95564253 2 Front sphere 1.4 petrol 55.42ea
95630610 2 Front sphere 1.7TD saloon, 4x4; GTi >3877 55.42ea
96024568 4 Front sphere 1.7TD estate; GTi RP 3878> 52.50ea
96087641 4 Front sphere 16V, ABS 52.49ea
96024566 2 Rear sphere Estate RP 3878>, except 1.7TD 52.49ea
96087642 2 Rear sphere 16V, ABS 52.49ea
95563928 1 Front strut top mounting 77.90
95650942 1 Front suspension strut 377.72
95563922 1 Front strut cap 2.00
95622818 10 Front strut return pipe 9.03ea
96127591 11 Strut return pipe clip 3.84ea
95591142 1 Strut return metal pipe 10.49
5437354 2 Accumulator sphere 81.41
95589236 1 Hydraulic pump Petrol except 16V 2411.32
520006 3 Hydraulic pump belt Early 1.4 petrol 9.33ea
91536298 3 Hydraulic pump belt Diesel except 6+2; 16V >4223 9.36ea
96030258 1 Return “octopus” 39.16
95567454 1 Main reservoir return hose Early 1.4 petrol 57.56
95603420 1 Main reservoir return hose Diesel & PAS 5167 62.99
96119048 1 Main reservoir return hose PAS 5168 45.64
95624231 1 Supply hose, reservoir to pump Petrol & PAS, except 16V 40.53
96093539 2 Pipe to brake valve RHD 3.88ea
96093540 2 Pipe to brake valve RHD 4.00ea
96093541 2 Pipe to brake valve RHD 3.79ea
96093542 2 Pipe to brake valve RHD 4.35ea
95596539 2 LHF brake pipe Non-ABS 10.32ea
95596540 2 RHF brake pipe Non-ABS 10.64ea
96093534 3 Front to rear brake pipe Non-ABS 20.51ea
96119932 3 Front to rear suspension pipe 20.61ea
96093536 1 Brake pipe to security valve 4.51
96093538 1 Pipe to front brake “T” connector 4.07
96033164 1 Pipe, flow divider to strg pinion Including 1.7TD 4102 12.18
40207A 1 Pipe set, pinion valve to PAS ram PAS, except 4x4 16.01
95592923 1 Pipe, regulator to pump Early 1.4 petrol 23.19
96028927 1 Pipe, regulator to pump Late 1.4 petrol 7.92
96020901 1 Pipe, regulator to pump 1.6 petrol, non-PAS 22.90
95576508 1 Pipe, regulator to security valve Early 1.4 petrol 22.97
95605517 1 Pipe, regulator to security valve Except 1.4 petrol 4101 20.43
95597151 1 Pipe, regulator to security valve Auto, non-PAS 4101 8.94
95567431 2 Pipe, security valve to front h/c 9.45ea
95595683 2 Pipe, security valve to rear h/c 18.08ea
95595685 2 Pipe, rear h/c to 3-way union 7.84ea
95595682 2 LHR suspension pipe 8.27ea
96117586 3 RHF suspension pipe 8.90ea
95603737 1 LHF suspension pipe 16.99
95567435 1 Pipe, “T” to LHF suspension pipe 9.04
95596564 1 Pipe, pump to flow divider Diesel & PAS 22.00
95603177 2 Pipe, pump to flow divider 1.6 petrol >RP 4101, 1.9 petrol except 16V 22.34ea
96016907 1 Pipe, pump to flow divider 16V & PAS 4223 19.54
96034027 1 Pipe, pump to flow divider 16V & PAS 4224 10.47
95596576 1 Pipe, regulator to flow divider PAS, except 16V 20.23
95596578 1 Pipe, regulator to security valve PAS 4101 13.18
95597151 1 Pipe, regulator to security valve Auto 4101 8.94
Brakes
4745L2 2 Handbrake cable 27.10ea
96011524 1 LH handbrake cable guide 4.85
96118522 1 RH handbrake cable guide Except 4x4 10.64
96035565 1 RHF brake disc deflector 7.03
95651079 1 Rear brake caliper 393.77
91537913 1 Rear ABS sensor Except 4x4 175.94
95661746 1 Front brake disc kit Non-vented 80.62
95624484 2 Front brake pad set 45.79ea
95661849 1 Rear brake disc kit 69.97
95650890 2 Rear brake pad set 40.20ea
95632790 2 Front flexible brake hose ABS 20.77ea
Gearbox, clutch & transmission
95612702 2 Clutch cable Early 1.4 petrol 23.55ea
96081712 1 Clutch cable 1.6 & 1.9 petrol, 1.7 & 1.9D 34.19
96081710 2 Clutch cable 16V & 1.7TD 28.29ea
2050W2 2 Clutch kit 1.6 & 1.9 petrol, except 16V &4x4 4529 225.40ea
96134964 1 Clutch relay lever Except 16V & TD 4529? 17.23
95567189 9 Clutch relay lever pushrod Except 16V & TD 4529? 1.14ea
211810 3 Clutch relay lever adjuster screw Except 16V & TD 4529? 4.66ea
2004A1 1 Clutch cover 16V, 1.7TD, 4x4 petrol 87.56
2050W6 1 Clutch kit Diesel except 1.7TD 231.47
205208 1 Clutch kit 1.7TD 261.92
95596491 ??? Long gear rod, from lever (upper) Early 1.4 petrol
95495342 1 Short gear rod (transverse) Early 1.4 petrol 14.22
95569317 2 Relay lever Early 1.4 petrol 42.45ea
95495340 1 Long gear rod, from lever (lower) Early 1.4 petrol 35.18
96006362 1 Short gear rod (transverse) Late 1.4 petrol 7.87
95636577 1 Long gear rod (transverse) Late 1.4 petrol 17.19
95635511 1 Long gear rod, from lever (upper) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4529 62.66
95495557 1 Short gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4529 13.75
96049753 2 Long gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4530 12.77ea
2454A4 1 Auto gear cable ball end 5.14
210948 1 Transfer casing gasket, large Early 1.4 petrol 12.57
210946 1 Transfer casing gasket, small Early 1.4 petrol 4.92
210912 1 Input shaft guide bush & seal Early 1.4 petrol 17.28
230214 1 Splined drive tube Early 1.4 petrol 15.91
211736 1 Clutch fork Early 1.4 petrol 14.15
212037 5 Clutch fork pushrod Early 1.4 petrol .79ea
329351 2 Outer driveshaft gaiter Various 18.55ea
328774 1 Inner driveshaft gaiter Various 23.39
329383 4 Outer driveshaft gaiter Various 20.41
329391 2 Outer driveshaft gaiter Various (ABS, GTi, etc) 32.71ea
329396 2 Outer driveshaft gaiter Solid plastic 23.21ea
95638113 1 Upper speedo cable Mk1 19.68
Engine & fuel system
? carburettor Early 1.4 petrol
95619435 1 Choke cable 18.39
95610428 1 Fuel tank pick-up & return unit Petrol 3738 15.00
95610427 1 Fuel tank pick-up & return unit Diesel 3738 23.85
156389 1 Fuel pulsation buffer Petrol injection 40.46
95594177 1 Metal fuel supply pipe Except petrol injection 9.47
95594178 1 Metal fuel return pipe 7.30
81640 2 Cambelt 16V 29.91ea
94957 3 Exhaust valve 1.6 petrol RP 4158>, 1.9 carb 24.35ea
94887 2 Inlet valve 1.6 petrol RP 4158>, 1.9 carb 14.41ea
51414 1 Crankshaft oilseal, flywheel end Early 1.4 petrol 17.92
51415 1 Crankshaft oilseal, timing end Early 1.4 petrol 6.60
118E5 2 Main bearing thrust washer 2.40 Early 1.4 petrol 4.00ea
118E9 3 Main bearing thrust washer 2.55 Early 1.4 petrol 15.80ea
118F0 2 Main bearing thrust washer 2.60 Early 1.4 petrol 15.99ea
209A6 1 Cylinder head gasket, std 1.20 Early 1.4 petrol 22.89
209A7 1 Cylinder head gasket, rep 1.40 Early 1.4 petrol 30.06
24939 1 Rocker cover gasket Early 1.4 petrol 5.96
25818 1 Oil filler cap Early 1.4 petrol, 1.6 & 1.9 petrol 9.97
95588076 1 Oil breather pipe Early 1.4 petrol 13.84
24974 1 Rocker cover gasket 16V 27.74
95639404 1 Air intake pipe, to filter casing? 1.7TD 21.20
570525 1 Alternator 1.6 & 1.9 petrol; 1.9D >RP 4921 148.36
91515530 1 Alternator Early 1.4 petrol 97.67
5705JN 1 Alternator Late 1.4 petrol, 5/88>9/91 91.98
5705JS 1 Alternator Late 1.4 petrol, 9/91> 122.82
5802EQ 1 Starter motor Diesel, CL5 167.40
580245 1 Starter motor Early 1.4 petrol 225.40
95495358 1 Aux belt tension roller Early 1.4 petrol 82.43
95588568 4 Front exhaust pipe Early 1.4 petrol 4195 59.19ea
96012198 2 Exhaust down pipe Late 1.4 petrol 4196 103.97ea
96076275 1 Front exhaust pipe 1.6 & 1.9 carburettor 107.82
95634351 1 Transverse silencer Flange fittings (e.g. TD, GTi) 78.19
96048419 1 Rear silencer Estate, 1.7TD & injection 77.27
30446 1 Sump gasket Early 1.4 petrol 9.90
95638829 8 Oil filter Early 1.4 petrol 11.27
113152 1 Oil level sensor 1.6 & 1.9 petrol 35.35
117824 1 Oil breather/filler neck 1.6 & 1.9 petrol, 16V 14.52
184472 1 RH engine mounting Late 1.4 petrol 26.21
1807P0 1 Lower rear engine mount, cast Late 1.4 petrol 30.09
120169 1 Water pump Early 1.4 petrol 86.94
120681 1 Water pump gasket Early 1.4 petrol .98
95593786 1 Radiator fan cowling Except 16V & 1.7TD 43.61
95634724 1 Radiator fan shroud Petrol except 16V 10.72
95633842 3 Upper radiator panel Diesel 3796? 6.73ea
95601742 2 Radiator fan shroud Diesel except 1.7TD 27.45ea
95635181 1 Radiator 1.7TD 267.21
95639271 1 Lower radiator panel 1.7TD 6.31
95593786 1 Radiator fan panel Petrol & diesel, GATE 43.61
95601821 1 Radiator fan panel Petrol & diesel, AOP 52.40
95591751 4 Lower fan panel bracket 2 fan system (e.g. 1.7TD, 16V) 6.75ea
95566628 1 Top radiator hose Early 1.4 petrol 52.16
95610901 1 Metal coolant pipe, back of head 1.6 & 1.9 petrol, except 16V 18.17
96170006 1 Top radiator hose 1.9D, 6+2 pump? (remote filter) 48.81
1307J5 2 Hose, exchanger to thermostat 1.9D manual (remote fuel filter) 8.37ea
1307W2 1 Hose, to metal pipe back of head 1.9D (remote fuel filter) 40.93
95587675 1 Top radiator hose 1.7D, 1.9D (remote fuel filter) 3796 25.99
96162612 1 Metal coolant pipe, back of head 1.7D, 1.9D (remote fuel filter) 3796 10.79
95638396 1 Top radiator hose 1.7TD 23.70
96164164 1 Bottom radiator hose 1.7TD 5638 38.89
190413 1 Fuel filter head, Roto Diesel Diesel (remote fuel filter) 73.02
95595188 1 Fuel filter unit, Purflux Diesel (remote fuel filter) 118.37
594029 2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 24.67ea
594031 2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 24.64ea
594047 1 Distributor cap & rotor, Bosch Late 1.4 petrol 41.48
594548 4 Ignition module Petrol, inc 16V 73.90ea
97533275 1 Ignition lead set Early 1.4 petrol 52.44
5967N9 1 Ignition lead set Late 1.4 petrol 43.86
597043 2 Ignition coil Late 1.4 petrol, etc 57.78ea
95636601 2 Ignition lead set Early 1.6 petrol 36.81ea
95659598 1 Ignition lead set Late 1.6 petrol 59.49
597042 1 Ignition coil 16V 48.06
9401445798 1 Air filter foam Early 1.4 petrol 4.16
9401906148 10 Diesel fuel filter, Roto Diesel Remote fuel filter 8.35ea
95608910 8 Diesel fuel filter, Purflux Remote fuel filter 17.30ea
SRV503 8 Petrol fuel filter Carburettor 4.66ea
Body mechanisms
95562445 2 RH external door handle 12.86ea
95562446 1 LH external door handle 17.42
95573650 1 LHF door lock mechanism For central locking 49.92
95573657 1 LHR door lock mechanism For central locking 53.31
95573658 1 RHR door lock mechanism For central locking 37.57
95564093 1 Tailgate catch Saloon without central locking 36.48
95566740 1 Tailgate catch Saloon with central locking 59.22
95564118 1 Tailgate lock button Without central locking 11.98
95610886 1 Tailgate striker Estate 3.31
95612096 1 Bonnet safety hook 13.07
75530712 1 Bonnet lock 33.28
95635160 1 Bonnet release cable 9.77
95608415 1 Bonnet striker pin Plastic bonnet 6.86
95564275XX ??? Rear seat back release handle
95570569 1 LHR seat back lock 23.86
95570570 1 RHR seat back lock 23.86
95649395 1 LHF electric window mechanism CIM 132.49
95649397 1 LHR electric window mechanism CIM 94.37
Body electrical
95623204 1 Front wiper motor, Bosch 96.57
95623205 1 Front wiper mechanism, Bosch 108.86
95589142 3 Front wiper arm 32.46ea
95495714 1 Windscreen washer spray bar 11.66
95633058 1 Front screen washer bottle 32.79
95633057 1 Rear screen washer bottle 12.77
643466 1 Windscreen washer pump 11.63
97533660 1 Wiper stalk 48.79
95618753 1 Dashboard fuel gauge, Veglia Except GTi 47.99
644590 1 Heater fan resistor 3710 45.38
6155J9 1 Digital clock 92.67
96070197 1 Ignition/door lock set Cross cut key 97.08
95662479 1 Ignition/door lock set Flat key 5956 62.70
96008430TR 1 Rear wash/wipe switch Saloon 4131 19.42
6239G4 1 Hazard flasher switch 32.06
97523100 1 Front foglamp switch 13.68
95634839TR 1 Heated rear screen switch 4131 28.78
95634839FXX Heated rear screen switch 18.08
96085588 1 Battery positive cable 1.6 petrol & 1.9 GTi 39.54
96091774 1 Battery positive cable 19TRS; diesel RP 4983> 20.24
96030080 1 Battery positive cable Late 1.4 petrol 18.28
95584782 1 Battery negative cable 19TRS, 1.4 petrol 8.97
95569042 1 Battery negative cable 1.6 petrol, 1.9 GTi, diesel 22.29
95588298FYD 1 Hazard flasher switch, grey Mk1 24.34
95588305FYD 1 Light switch, grey Mk1 12.57
Body structure
95630375 1 RH headlamp mounting panel 17.21
95605366 1 Bonnet seal, above headlamp 4.28
95612062 1 LHR wing Mk2 saloon 177.26
95612063 1 RHR wing Mk2 saloon 177.26
95568456 2 Fuel filler flap 40.11ea
95631758 1 Front subframe Early 1.4 petrol 249.64
95563211 2 LHF wing Mk1 135.10ea
95563210 2 RHF wing Mk1 141.93ea
95619149 1 Front bumper Mk1 167.28
95587856 2 Rear panel assembly Saloon 138.63ea
95633140 1 Rear subframe Except 4x4 408.87
95563310 2 Front bulkhead cowl top 52.20ea
95631043 2 Front bumper side bracket 10.79ea
95645962 1 LHF inner arch panel 167.47
95645961 1 RHF inner arch panel 104.49
95615414 4 LHF inner wing side panel 51.25ea
95615413 2 RHF inner wing side panel 43.65ea
95595027 1 LHF chassis leg 59.89
95595026 1 RHF chassis leg 111.84
95560885 1 LHF chassis leg end bracket 7.60
95560884 1 RHF chassis leg end bracket 5.50
95575083 1 Battery support bracket Except early 1.4 petrol 31.31
95587858 1 LHR lamp panel Saloon 41.20
95617022 1 RHR inner wheel arch assembly Saloon 163.66
95587860 1 LHR upper inner wheel arch Saloon 93.86
95567708 1 LHR floor leg Estate 22.58
95616854 1 Rear crossmember Estate 116.46
95616852 1 LHR towing eye Estate 31.11
95616853 1 RHR towing eye Estate 34.64
95615179 3 Lower front crossmember 51.54ea
95616626 2 Locking plate, front panel 15.35ea
Body trims & mouldings
95619577 1 LHR wheelarch protector Estate 24.31
95619579 1 LHR wheelarch protector Saloon 26.23
95604802 2 Rear wing upright seam trim Saloon 2.75ea
95570784TR 1 Front seat backrest moulding 24.84
95661828 1 LHF bumper duct/cover 16V Phase 2 47.26
95595330 1 Wheel trim Mk1 RS, etc 20.36
95632315TL 1 RHF door capping, grey 15.78
95619108 1 Rear bumper/tailgate moulding Estate 83.75
95619724 2 Tailgate moulding insert Estate 25.85ea
96059179 1 Badge, TZD TURBO Plaque style (earlier) 6.22
95582304 5 Bonnet chevron, chrome 4.58ea
95609863 2 Bonnet chevron, black 3.40ea
95568167 3 Bonnet catch protector .41ea
95589671 4 Bonnet buffer .99ea
95589346 3 Wing/bonnet rear edge seal block 1.97ea
95643658XX 1 Front bumper corner end set, black 6.77
95643658YB 1 Front bumper corner end set, grey 6.53
95624914 1 LHR arch moulding 16V, late Phase 1 & Phase 2 4496 149.69
95653193 1 LHR door moulding 16V Phase 2 89.13
95653195 1 LHR wing moulding 16V Phase 2 38.47
95612059XX 1 RHF wing moulding, 27mm 4754 7.92
95633444 1 RHF wing moulding, 27mm Stainless insert 4754 4.37
95633445 1 LHF wing moulding, 27mm Stainless insert 4754 4.91
95633443 2 LHR wing moulding, 27mm Stainless insert, saloon 4754 16.14ea
95612064XX 1 LHR wing moulding, 27mm Saloon 4754 9.73
95632337XX 1 RHR wing moulding, 27mm Estate 4754 17.07
95612072XX 3 RHR door moulding, 27mm 4754 16.40ea
95633439 1 LHF door moulding, 27mm Stainless insert 4754 23.39
95633438 1 RHF door moulding, 27mm Stainless insert 4754 22.16
95612058YB 1 LHF wing moulding, 27mm 4755 7.92
95612064YB 1 LHR wing moulding, 27mm Saloon 4755 9.17
95612065YB 1 RHR wing moulding, 27mm Saloon 4755 9.17
95632337YB 1 RHR wing moulding, 27mm Estate 4755 12.45
95612069YB 1 LHF door moulding, 27mm 4755 15.82
95612070YB 1 RHF door moulding, 27mm 4755 15.82
95612072YB 1 RHR door moulding, 27mm 4755 15.82
96044541YB 2 LHF door moulding, 52mm 4755 38.94ea
95656536 1 RHF wing moulding, 52mm Painted (Athena, Hurricane) 4755 27.74
95653193 1 LHR door moulding, 52mm Painted (Athena, Hurricane) 4755 89.13
95585105 1 RHR wing anti-chip tape Mk1? 5.58
CIT8021 2 Pinstripe St Tropez 10.91ea
CIT8055 1 Pinstripe Rendezvous 11.42
CIT7209 3 Badge Meteor 6.81ea
CIT8511 1 Badge, 19TXD Later version 3.01
CIT8090 1 Stripe kit Hurricane TZD Turbo 24.00
95612078 1 RHF plastic arch liner 37.81
95612060XX 2 Front bumper side seal 27.06ea
Glazing
95619450 4 Windscreen seal Saloon 50.79ea
95619451 1 Windscreen Clear 136.97
95653182 1 Windscreen Green tint 4496 142.89
95560673 1 RHF door glass Clear 53.50
95560674 1 LHF door glass Clear 29.72
95560676 1 LHF door glass Bronze tint 4495 27.00
96050176 1 LHF door glass Green tint 4496 52.19
95633344 1 LHR door glass Bronze tint 4495 32.49
96050178 1 RHR door glass Green tint 4496 55.52
96050179 1 LHR door glass Green tint 4496 62.95
96050180 1 RHR door ¼ glass Green tint 4496 17.94
95496514 1 Tailgate glass Clear, heated, saloon 91.10
95606651 1 Tailgate glass Clear, heated, estate 102.62
96051539 1 Tailgate glass Green tint, heated, saloon 4496 130.65
95592669 1 Tailgate glass seal Saloon 20.92
Miscellaneous
95552823 1 Spark plug wrench 3.73
96078629 1 Wheelbrace 4588 8.31
95495316 1 Heater matrix 75.40
95595456 2 Air extractor vent filter Saloon 2.15ea
95597261 1 Air extractor vent filter Estate 1.42
95632283 1 LH mirror, manual 56.44
96077969 1 RH mirror, electric & heated 101.98
95619708 1 LH mirror glass, electric 14.41
95633648 1 Mirror control knob, manual 1.41
95624967 2 RH mirror control knob, manual 5.10ea
95638372 3 Mirror handle foam seal .76ea
96047324 1 Heater hose to rear housing 1.7TD 5637 25.67
96090355XX 1 Coin box 14.67
95570247 1 Boot trim, rear panel Saloon 21.80
95576719 1 Rear lamp earth harness Saloon 15.54
95569072 1 Rear lamp harness, between lamps Saloon 21.89
95637364 2 Front brake pad wear loom 28.05ea
95561136 1 Co-axial cable 18.68
6451Z7 2 Heater control knob, grey 7.33ea
7903076124 1 Heater control cable clip .47
95631221TR 1 Glovebox lid release button 4131 13.16
Hydraulics
Brakes
Body mechanisms
Body electrical
Body structure
Glazing
Miscellaneous
- x 25
Aerodynamica
I'd be keen on a HP pump but couldn't breathe at the price listed - are these dealer prices? - I wouldn't know since I've never bought any part from a dealer (except for the Xantia plastic height corrector link but that was about £4!)
I'd also like some ignition parts.
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
The prices next to them are new retail but he knows he wont get anwyhere near that for them. Just bid him a really cheap price and negotiate from there! They would have had theses bits in stock for at least 10 years so would ave been written off by now so anythings a bonus!.
Thats what im doing!
Aerodynamica
Depends on how cheap everything is I guess, they wont ever sell them retail or trade to another garage for that matter so may aswell get something for them as its dead money otherwise.
I dont imagine many takers for the floor panels etc, but the Hurricane Stripe Kit is a bit of a rarity, Anyone got a triton green car they fancy converting?
- x 25
Matt H
Matt H
- x 25
