All about CAMBELTS
Ian_Fearn
All about CAMBELTS
Post by Ian_Fearn »
I want to change the cambelt on my Golf TD and am a bit confused as to exactly how i need to lock the camshaft in place and how i finally tension it.
Does anybody use special tensioning tools or locking tools?
Over and out from me
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Does it have an XUD under the lid? :twisted:
1991 Landrover Discovery
1995 VW Golf SE
Ian_Fearn
Post by Ian_Fearn »
A Turbo XUD with 75BHP? ER NO! Citroen had the sense to give their turbo diesels some grunt!
AlanS
Post by AlanS »
My son has a gadget he uses on these ricey racers he works on that just locks the cam gears in place that looks like an inch square box section, and then he pins the crank. Slacken tensioners, belt off, belt on, retension, lockers off job done. The only way it can be a problem is if there's an issue as regards the rotation of the tensioners as applies to PSA 16V petrol engines.
Failing that, Anders old trick of marking the old belt with white out and corresponding teeth on pulleys, mark same teeth on new and count the teeth between marks and fit so marks on the sprockets align is as simple as it gets and works every time.
Alan S :wink:
Terry Brooks
Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Post by Terry Brooks »
I've never done a cambelt on a Golf [or a BX for that matter] but would the trick work of ........Cutting the belt in half [longways,obviously] ......then removing the half on the outside of the pulleys,putting the new belt half on and then cutting off the last half before sliding the new belt completely on. Dunno if it'd work on a car [BX or Golf or any other] but I've done bike engine cambelts ["Rotax" engines] like so on several occassions.
HTH
Terry
Ian_Fearn
Post by Ian_Fearn »
Jon, what about the final tensioning?
Its described in the Haynes as AAZ, mechanical fuel injection turbocharged.
The marks on the flywheel and engine are there to match up and i understand the part about the camshaft locking now....... BUT
How can i tell if i've got the automatic or manual tensioner?
Is there a spring on the automatic one?
tom
Citroen Sorceror
x 38
Post by tom »
VW main dealer wallet puller, I expect. Vorsprung durch chequebook.
mnde
Meteor Man
Post by mnde »
Argh, I've heard scary stories about VAG dealership prices. Like a really scary amount of money just for a back box for a Polo... and if you want to refit the cover over the rear wiper if some batard has nicked it. Ouf.
Mark.
