My engine is really slow to turn over, won't even spin - just half a revolution at a time. Replaced the starter just now - still the same. I have a 2 month old battery, so I had ruled that out (also because it was the same hot or cold), and have bypassed all the leads to eliminate poor contacts. I have also put a booster pack on but no improvement.
I'm going back out to try and have a think, but has anyone any good ideas?
Strange starter problem
- BX Digit man!
Re: Strange starter problem
Including the battery-to-engine negative lead?mat_fenwick wrote:have bypassed all the leads to eliminate poor contacts.
Next thing to do is start checking voltages all over the place to ensure there isn't (or to find) a volt drop that shouldn't be there.
- x 94
I'm feeling quite stupid now, having wasted £40 on a new starter...
What I had don was clip a jump lead to the battery negative terminal, and the other end to the starter bolt. It was only when I got a friend to crank over the engine with me watching that I saw the smoke 'escaping' from both the jump lead, and the thin negative lead to the body!
I'm still puzzled why it would suddenly fail - it fired up fine on the (frosty) Sunday morning, but a few hours later with the engine hot there was next to nothing. Spent an enjoyable half an hour trying to bump start it on my own in a flat motorway services car park.
I will replace the negative lead, and the battery terminal(s) too, ideally with something I can solder.
