Hi - just a quick question if that's ok.... My recently bought BX 14 seems to have little or no antifreeze in it. Am I safe to add some blue antifreze to the coolant? I have read horror stories of different antifreezes being mixed and engines being wrecked.
I guess it'd be best to start from scratch and drain and flush the rad but don't know when I will have the time.
Thanks,
Rob
Antifreeze....
rob-81
Antifreeze....
19 TGD estate
17 TZD Turbo hatch
17 TZD Turbo hatch
Its getting colder, so its more than likely going to cause the inevitable, if you dont have time, just drop it off at a garage for them to do it, better safe than sorry.
I was running my TZD without any antifreeze in (i didnt realise), 1st cold snap i thought the heater in the car was taking quite a while to release any heat, a few miles into my journey & i had the red lamp of death come on. Pulled up into a carpark & switched car off, got AA out who diagnosed no antifreeze. Luckily for me, there was no damage caused, & by the time the AA arrived, the pipes which had been frozen had managed to defrost themselves. Thats a lesson i'll never forget.....
Re: Antifreeze....
It's a good idea to give a backflush with a hose pipe and then refill using Barr's Professional Flush (available from GSF)+ water, run it for a journey and then empty and flush again before refilling with antifreeze to the prescribed strength.rob-81 wrote:
This Barr's stuff eliminated a red light problem I was starting to get even though the temperature gauge was reading normal.
