Correct alternator belt?
ed4ferrets
Yahoo Messenger: ed4ferrets@yahoo.co.uk
Post by ed4ferrets »
GSF had none in stock so got this from a local factor. Before I attempt to fit it can anyone confirm QH part no QBR5700 is correct for a TD?
'94 XM 2.1TD Break
'63 Renault Caravelle
It should!
The 5 relates to the number of peaks on the belt (the V's)
The 700 relates to length, 700MM, which is correct for a TD so you shouldn't have any problems mate.
ed4ferrets
Cheers Doc, didn't want to remove old belt only to find new one wrong size :shock: :x
'94 XM 2.1TD Break
