Urgent flasher relay
ed4ferrets
Where is it on 93 tzd and looks like what please? no indicators or hazards, fuse is good
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
mnde
- Meteor Man
Hi Ed, please see the following:
http://www.tramontana.co.hu/citroen/electric/fuses.php
The relays are behind the fuses in the box. It could be that the traffic indicator one has merely worked loose. That's what happened to me with one of the other relays once - took ages to locate the fault that was blowing one or two related fuses! Turned out that a passenger had probably kicked the fusebox open with her foot and disturbed the relay.
Cheers,
Mark.
Cheers,
Mark.
mnde
- Meteor Man
- x 25
ed4ferrets
Cheers Mark, I only got the benefit of your wisdom on arriving home after the witching hour
Luckily a text from Doc prescribing the hammer treatment to the offending relay proved to be the right medicine
Flashers now erratic but at least working
Ah yes Phil, footprints on the rooflining, happy days
'94 XM 2.1TD Break
'94 XM 2.1TD Break
I'll dig you a unit out mate.
I shall never again be increasing the carnal score anywhere near my cars, not after the last one put a bloody great dent in the O/S wing...
She didn't even look that fat.
Ho hum.
Ho hum.
