How do you remove the steering wheel on a Mk1 BX, the centre badge does not appear to lift off.
I don't want to damage it so any help will be greatly appreciated.
Steering wheel removal (Mk1)
artic-steel
- BX Digit man!
My memory might not be what it used to be, but this is one job I'll never forget.
Simply split the steering column at the universal joint just above the drivers feet and unbolt it from it's anchors under the dash.
Mine was only a nightmare because I was replacing the pinion valve.
