The oil level gauge
Aerodynamica
The oil level gauge
Post by Aerodynamica »
The oil level gauge on mt Mk1 doesnt work. You switch on the ignition and nothing - start the motor and not a peep.
However! there was an occasion where the gauge did spring to life!
On one occasion where the engine was taking longer to catch starting from cold, the oil gauge jumped to life! but only jerked the needle in time to the engine churns. It never actually read a level of oil.
Before I fully investigate it I am wondering if you guys would know of a simple common fail point for the electric oil level sender? wishful thinking?!?
G
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
Yeah the plug/connector! Mine melted once! :lol:
stuart_hedges
Post by stuart_hedges »
Mine does that! It's a gauge for measuring how long the engine took to fire on that occasion.
My plan of action is to completely ignore it.
They all do that mate, they're crap.
The one in the valver is so part time it's laughable, and I replaced all the bloody wiring right back to the guage and the sensor itself.
It's a naff idea TBH, but if you want it to work I'd start with the plug too, down teh back of the engine. They do indeed usually melt / break up / fall off / get covered in oil and shit etc...
mnde
Meteor Man
Post by mnde »
What he said.
Use the dipstick Luuuuuuuke!
On both my BXs I could switch the ignition on and off several times and the oil level gauge would read something slightly different each time.
Ah but I forgot it then switches to oil pressure sensing mode...
I found some more techie info here: http://www.tramontana.co.hu/citroen/ele ... hboard.php
(scroll about 3/4 of the way down)
Cheers,
Mark.
