Radius arm bearing kits
Alastair
Whilst I have no doubt they are still available.....has anyone got any part number? Any make will do Quinten Hazel etc? I can cross reference. I bought a kit about a year ago, for my other car, and didnt keep a part number record!
bexxy
Rear arm bearing kits, I bought 2 sets from GSF car parts a month ago and paid £82. SKF (VKDA 23001). Mark.
2010 Berlingo 1.6 hdi (15000 miles
2009 107 silver 5dr (9k)
2006 C15 Rouge , windows all round (27k )
3 Honda C90 cubs ( 24miles, 400miles, 10k)
2010 Suzuki van van 125 (172 miles )
Raleigh Bomber pushbike
- Our Trim Guru
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
- x 27
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Hard to say Phil but if one is in need then you 'may as well' do the other. You can buy just the bearings which I think are about £8 for a pair + VAT (can't remember where I've seen them) I've been wondering if the taper needle roller bearings can be replaced using a sealed caged ball bearing .
Geoffrey Gould
Hi bearings well the advantage of taper roller bearings are that they can be adjusted easily (shims) to allow for 'manufacturing tolerances' and to set up the pre-loads. They also designed to cope well with the sideways thrust put on the arms with cornering etc.
Ordinary ball bearings are designed to cope with radial thrust but not axial thrust. Ok there are special ball races made to cope But they are non-adjustable and require accurately machined housings and spacers etc. and would be much more expensive to use in the BX aplication.
Taper rollers do the job.
Cheers.
Geoff.
Cheers.
Geoff.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
Aerodynamica
I don't know if it's of any help but I tend to replace only the actual bearing shells and tracks for the arms - they're about £8 each from Euro car parts and you need 4. You re use the thrust washers, polished support tubes, 24mm nut and bolt and the rubber seals.
Is the kit you're talking about the one that replaces all of the components in one go?
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
- Our Trim Guru
It I'm mot treading on any toes - this is the kit for the whole lot. Whether you need to use the whole lot depends on the job in hand - which boils down to how well the previous owners have looked after the car. The inner plastic tube in the kit - which some regard as optional - is very likely to be damaged during removal of the old bearings.Is the kit you're talking about the one that replaces all of the components in one go?
Rear arm bearings that've been left too long may be candidates for extra parts replacement (where there's been corrosion or breakup inside - though not too severe).
Alastair
