er.. yes .. on the car
accelerating or decelerating gently from any given steady speed with the engine running between 1-2000 rpm, the car lurches forwards and backwards, most noticeably and annoyingly in third gear. It has been confined to between 1-2000 rpm until recently but now seems to remain thro to 2.5-3000 rpm. Only keeping the accelerator dead still on a level road can i stop it, or it goes on accelerating hard too. So i'm doing a fair amount full throttle accelerating up to 40mph or whatever the limit is
initially i thought it was due to the worn lower engine mount, but i think its just making it more noticable.
The factoids:
The engine always idles perfectly, no fluctuation and revving is smooth.
New fuel filter recently and i have swapped the fuel filter housings (same on each) on my cars as the primer in one was bubbling fuel from under the plunger. The replacement seemed ok, but i guess it might not be.
The metal fuel lines under the car i replaced 6 months ago.
Pretty sure its not the clutch.
I could replace fuel lines with clear from filter to pump to check for air, that could be my 1st step, but I'm wondering what else i could check. The last rubber bits near the tank must be pretty hard to get at/replace?
The diagnosis:
Any thoughts on a likely candidate? :
a/ a knackered pump (lucas/roto) - seals etc?
b/ a blockage in the tank - is there a filter in there before the fuel supply line?
c/ leak off pipes between injectors - these are looking pretty perished and frail, although the longer ones on the pump look good.
d/ rubber supply pipes before or after fuel filter admitting air
PS. Cooling system overhaul stage 1 commences this weekend!
