Charging problem
jonathan_dyane
Charging problem
Ok, so following the demise of the BX engine, and having killed an AX within about 40 minutes of buying it, I went out and bought a Xantia 1.9td today. I had thought that (aside from it's distressed appearance) the main issue was a somewhat collapsed drivers seat (it's a somewhat-leggy ex-minicab) however it would seem that having just had to get the bus home to pick up a spare battery, all is not well with the charging system...
To cut to the chase, aside from the obvious lack if charging, the battery light either doesn't light or flickers, and only glows dimly. Connections seem ok. Should I try and dick around with it, or hotfoot to the scrap yard in the morning in search of another? BTW, it is a different alternator to the BX one; the type with the internal fan.
- BX Digit man!
jonathan_dyane
Particularly on a SundayDavidRutherford wrote:Most probably the brushes are worn down to nothingness. If you can get a replacement alternator I would do so, as although changing the brushes is fairly easy, they're not easy to get hold of.
I tried tapping it with a hammer to try and get a bit more mileage, but it wasn't having any...
Should be plenty in the scrapyard, anyhoo.
Ta,
jonathan_dyane
Or perhaps not. Turns out there are eleventy-billion permutations of non-interchangable alternators. Bloody Xantiasjonathan_dyane wrote:Should be plenty in the scrapyard, anyhoo.
I can see trying to repair mine with the innards of another, Should be fun
Mike E (uk)
jonathan_dyane
I bought a cheap multimeter today (most of my tools still in the boot of the BX 200 miles away) and found that the alternator was not charging at all. Also, in the cold light of day it was apparent that the HP was leaking, and being mounted directly above the alternator LHM had dripped into the alternator, gone right through it, and then was happily dripping out of the other side. I guess I ought to fix the HP before I replace the alternator then...Mike E (uk) wrote:I would check the charging voltage in case it is something else.
Unlikely, but worth 2 minutes of your time.
Mike
As I have a spare battery, I am currently running with this in the passenger footwell and driving on the battery, and can swap and recharge the other off the car when necessary. Better not play that game for too long though, otherwise I'll end up having to buy a battery as well as an alternator. Ho hum.
CitroXim
- Sir Jim of the Databases
Language Jonathanjonathan_dyane wrote:Bloody Xantias![]()
One more thing to check before getting stuck in is that the ignition lamp wire (the thin one) is well connected. Sometimes if they come adrift or don't make a good connection, that can cause it, a duff bulb can too. Very unlikely but worth a check. If the light is on, then OK.
If you need to change any instrument bulbs in a MK1 Xantia, you really will have reason to say "Bloody Xantias"
Jim
- Our Trim Guru
I'd reiterate citrojim's advice on the alternator connections after some experiences with the alternator on my BX last year.
On that occasion I ended up buying a new battery when I didn't need to, made a mess of fitting a replacement alternator(admittedly in crappy weather conditions), and made a mess of an alternator adjuster bolt too. In the end, with the aid of some excellent electrical help, the problem was resolved by combining parts (mainly brushes) from two alternators to make a better single one, and then testing and/or remaking every connection until they were as good as humanly possible.
Those good connections are absolutely vital. If you have any doubts about the wires or terminals at all then make sure you can allay them by rigorous measurement, cleaning and/or replacement. Lack of that on my part made a potentially short job into a much longer one.
Hope the current battery is a good'n'sturdy one.
jonathan_dyane
Well, I took off the brushbox thingy checked it visibly, and found that the brushes were fine. I could have tried another brushbox/regulator assy, but I decided to go for a recon alternator for 72 quid delivered which seemed very fair. Better replace the seals on the HP before I fit it tho!
As for the Xantia (perhaps controversially) I have to say I find them quite a pleasant car. Very different to the BX, if it weren't for the awful seats I would be rather enjoying the change. Tempted to borrow the BX's front seats while it's off the road...
c90cassette
hi jonathan
hi jonathan,yes you are right about the xantia seats are crap compared to bx ones.ive got pair off a pug 306 xld the dark grey and black pattern not the lighter ones which show the dirt.you are welcome to use them if you want.they are good,in my house in l7 near edge lane. .ps is your xantia dark blue p reg with towbar?bye rob.
hi i am rob in liverpool 1989 bx 17 dtr turbo
jonathan_dyane
Re: hi jonathan
Ooh, I am interested in the 306 seats; I have a somewhat tricky back, and even on my 12 mile commute I can feel my back twinging by the time I reach journey's end... Will you be around at the weekend? Oh and yes, well spotted; that is indeed my car!c90cassette wrote:hi jonathan,yes you are right about the xantia seats are crap compared to bx ones.ive got pair off a pug 306 xld the dark grey and black pattern not the lighter ones which show the dirt.you are welcome to use them if you want.they are good,in my house in l7 near edge lane. .ps is your xantia dark blue p reg with towbar?bye rob.
Oh, and guess what? Now I have bought a new alternator the old one miraculously seems to have started working again! I guess that the brake cleaner I doused it with managed to shift the LHM from wherever it was messing things up...
jonathan_dyane
Thanks Matt, alas I have to report that I find the Xantia seats rather disagreeable even in non-collapsed form,,, Might end up putting a pair of BX TX/TZ/GTI seats in if I manage to come by some, but otherwise the 306 ones will be an improvement!mat_fenwick wrote:I have a set of good Xantia front seats and an alternator you can have, I am in North Wales so not too far from Liverpool...
Would have taken you up on the alternator, but alas the recon one is currently already winging it's way towards me...
Ah, but these seats are famous...
I took them to the CCC rally last year (in the absence of deck chairs), and after a few drinks I completely forgot them the following morning! Chris (Doc) brought them back to his farm, and stored them till I could pick them up. Can't even give the things away, and when I leave 'em in a field on the other side of the country, they still get back to me!
