BOLTS FOR ALLOYS
Chris Abbott
BOLTS FOR ALLOYS
Hi guys, ive managed to get myself a set of alloys, i now need the bolts to suit, has any body got any knocking around? It doesnt need to be a full set, any odd ones will do and perhaps i can build a full set up. Thanks to Dave for my GTI wheels- youre a true gent!
Mike E (uk)
http://www.bxclub.co.uk/forum/viewtopic.php?t=9589
I still have these, but you will need 3 more.
Mike
Mike
- x 94
Mike E (uk)
Mike E (uk)
- x 94
Mike E (uk)
If the AX bolts are not flat faced, which car has bolts which are identical to the BX alloy bolts, but about 10mm shorter?
I had a set of these once, which came with a set of BX alloys I bought.
I binned them when I saw they were not long enough.
They could have caused some unpleasantness if they had failed, so I write this as a caution.
I thaught they were from an AX.
Mike
Mike
- x 94
205/309 GTiMike E (uk) wrote:If the AX bolts are not flat faced, which car has bolts which are identical to the BX alloy bolts, but about 10mm shorter?
Mike
AX ones look like conventional steelie bolts, with a tapered seat.
Much like ZX alloy bolts then..
Indeed, the pug bolts are shorter, and I got caught out when I first got the alloys on the BX, as I had no bolts, so buggered off down the scrappies and got a set from a 205.
Wound them in and thought "fook me, they dont go in much!".
Then spent, er, rather alot at the main stealer buying brand new bolts...
In bags of three since thats how they come!
