James' BX
James' BX
I'm sure most of you are aware that I payed too much for this car, and as it turns out there are some problems with it.
Here are some pictures:
The turbo isn't working, this thing takes 25 seconds to reach 60 which isn't right to anyone's standards! The spheres also need replacing, this all costs money I don't have.
You could call it bad luck, but I love this car and I'll do what I can to keep it on the road.
There's one thing missing from the back - I need to get one of your BX club stickers
Updates on this car as they come, thanks for reading.
- DavidRutherford
- BX Digit man!
- Philip Chidlow
- x 25
I actually think the alloys suit the car.
It is a good looking car though IMO and I really hope things work out for you.
About the Turbo, the garage has discovered that the accelerator pedal on our Hurricane is slightly wonky and is going to one side when accelerating so we're not feeling the turbo, it's not an expensive job and is getting fixed soon.
The car still easily accelerates though but you just don't feel the turbo as much as you should, is this similar to your problem?
K BX 19 TXD
J BX TZD Turbo Hurricane
J BX TZD Turbo
J BX TZD Turbo
Sounds similar, I read about this problem before I signed up. I can vaguely feel the turbo now (after yesterday's garage rip-off experience) but it's nothing like it should be. The pedal seems fine to me, though you might be right.Hurricane wrote:is this similar to your problem?
Still takes a good 24/25 seconds to reach 60 ... way off the mark, which makes me keep with the idea that my turbo isn't giving any power, or it's minimal.
Here are some quick pics of the rear wheels:
It might be that since David pointed the arm bearings out it's been playing on my mind, but today when driving I could hear creaking I'm aware that there's a thread about similar problems in the technical section.
They do look worn to me, the question is can you drive on worn bearings?
Edit: the other wheel looks about the same as this one.
Oh the dreaded creak! Sends shivers down my spine that does, we had the exact same problem with our old Hurricane. Have you tried pushing up and down on the back of the car and seeing if it creaks?Tourist wrote:It might be that since David pointed the arm bearings out it's been playing on my mind, but today when driving I could hear creaking
Also Mr Chidlow noticed on some pictures of our Hurricane that the arm bearings may be on their way out but we haven't had them checked yet.
Here is a picture of the car, the lean on the wheels actually looks worse than it is!
http://i276.photobucket.com/albums/kk32 ... 1844-1.jpg
Although there is no creaking on ours at all as of yet.
K BX 19 TXD
J BX TZD Turbo
J BX TZD Turbo
Nice car hurricane, I'm not sure about my wheels, pretty sure there's no creaking when the car is pushed downwards as my friend kept doing it and I never heard it.
It's just every now and then when you go over a bump that's big enough ... I can get them looked at when the car's back up on a ramp (monday with luck) but do you think it's ok to drive over the weekend? Wouldn't want to cause even more damage.
What I really need is a local BX-er who can help me out a bit as I'm not in the know about BXs and cars in general. Is anyone local to me? Postcode: OX49.
Well I'm no expert but we drove ours creaking from Preston to Scarborough and back and about 50 miles whilst over there last August and it came through unscathed so hopefully yours will be ok for now.Tourist wrote: but do you think it's ok to drive over the weekend? Wouldn't want to cause even more damage.
Although don't take my word for it your best seeing what others say first.
K BX 19 TXD
J BX TZD Turbo
J BX TZD Turbo
- Philip Chidlow
- x 25
Although it's going to continue to deteriorate, the chances are you can drive around with worn bearings for quite some time. I know I have in the past. Strictly speaking I should do my o/s one, but money's tight, (and time) so it'll have to wait until next month.
A bit of a lean, you can live with for a short while. Best get it done if it starts to creak a lot though!
- DavidRutherford
- BX Digit man!
In which case both of your rear arm bearings are completely knackered. I'd guess that any damage to the bearing/seal surfaces in the arm is already done.Tourist wrote:Edit: the other wheel looks about the same as this one.
I suspect the car handles like a wayward shopping trolley in its current state.
Well for that the first thing to do is check your spheres and if they're hard then you need to attend to this without further delay!Tourist wrote:I can feel every single bump as I drive over it.
You can easily tell if the spheres are sh**ged when you drive over the "cushions" or "sleeping policemen" as a BX handles these smoother than any other car. Any "bangs" or "leaps" and spheres need to be changed in pairs, front, back or both.
They are quite inexpensive from GSF, why wait to damage your suspension components?
- x 88
Just a thought....a Xantia I bought once had no turbo either, with no funny noises. Accelaration was woeful, smoked badly to begin with but fine after a while.
Cause? Main pipe from intercooler had come off. Jubilee clip failed. I take it you've checked all the pipes?
Otherwise it's a straight car. Needs sliver speedlines though.
