(Well, actually while waiting to be able to afford to put decent rubber on them!), I refurbished the old trims that once belonged to 'ELF' and were given to Mulley some time ago. Thanks to his generosity (and a £10 donation to the BXagon in payment) I got them back
So, thanks to Mr. Mulley, some sandpaper, a can of primer and some aluminium paint: voila - original spec:
While waiting for the Speedlines
- Philip Chidlow
- x 25
- Philip Chidlow
- x 25
Ta very much.
There's some fairly urgent welding to do next month and then the fun starts with struts, arm bearings et al... But the car is a credit to Dave Saville, it's previous owner.
(Trims: They're wired onto the trim rings already but I think I'll tie the whole assembly to the wheels themselves too).
Phil, you really crack me up I thought i had the worst memory in the world, but no, its you phil
Just for clarification, i know nowt about this. I am however of the current generation, where i will gladly accept credit for something i havent done
Over to you phil, part 2?
- Philip Chidlow
- x 25
Erm, i wont ask what it is that you want me to do for you
- maxgreenwood
I can't believe this car, i've seen a few pic before, just goes to show distance travelled doesn't always equal degradation. A beauty!
even the driver's door has no hint of droop, it makes sense its been lavished with lashings of TLC over the years
'90 16TZS (m), White, 86k
