MK2 19RD ESTATE
MK2 19RD ESTATE
Had a email earlier from a guy who wants to fine a home for a an old 19RD estate.
It reads as follows;
Dear Tim, I gave a D reg. 19RD diesel estate to my friend Sally, in South London.It has done 130000 miles and has had a recent service (2000miles ago)and has abrand new radiator. It has a fluid leak from the octopus, but she keeps puttingLHM in it, and pootles off round London in it regularly.Its Tax is due up at theend of the month so it needs a new home fast otherwise it'll become a ChineseFridge.
It is a very early MK2 in red, looks to be half tidy with a TZD front bumper (fogs and splitter)
This car is FREE to a good home who will return it to the road,
Please contact me for contact details. Car is in south london and needs to be collected within 2 weeks.
DavidRutherford
- BX Digit man!
- x 116
Got any seats
Hi Tim
You haven't got a GTi type drivers seat (with TWO adjusting knobs) surplus to requirements by any chance ??
Mine is bent a bit and consequently is not adjustable any more.
DavidRutherford
- BX Digit man!
Spoken to the blokey who's number you gave me, but he's not the custodian of the car. I was expecting a call back from him, but I believe I was on another call at the time, so I'll call him back tomorrow.
The car is hopefully destined for a colleage's son, after a bit of octopus surgery and a new MOT.
Great stuff David.DavidRutherford wrote:Spoken to the blokey who's number you gave me, but he's not the custodian of the car. I was expecting a call back from him, but I believe I was on another call at the time, so I'll call him back tomorrow.
DavidRutherford
- BX Digit man!
Saw this car today, and assuming everything goes to plan should be recovering it from Lundun next weekend.
It's got problems though. The only key has been sheared off in the ignition barrel, and hence not only can the car not be driven (the stub doesn't work unfortunately), but it can't be locked or get any more fuel into it.
The passenger seat has been changed for a later TZ spec seat. The front of the car has clearly had a stoff at some point as it's got the front off a TZ spec car on it, which means a short-nose bonnet, and splitter & (inoperative) fogs.
The LHM leak is reasonably severe given the number of empty gallon containers in the car, although it has apparently been leaking for a fair-old-while.
And both the tax and MOT are out.
... But I do like it. No idea why, but I do.
stuart_hedges
DavidRutherford
- BX Digit man!
Well that was a bit of a bloody disaster.
The main issue with this car for getting it transported was the fact that the key had been sheared off in the ignition barrell. Not a problem, as the car came with a replacement barrell and key. Brilliant.
So, yesterday evening I pull the steering column to bits, beat out the old barrell (fairly easily actually), remove the radio for access (very badly wired) connect up the new barrell (just leaving it loose on the passenger floor, and turn the key.... It tries to start, but the battery is too flat. Unfortunately, the car had a nasty 1980's car alarm fitted to it, which detected that the battery voltage had dropped to near-zero, and then when the passenger door was opened, decided to go off. We have no key, no remote, no instructions... nothing. Wait 30 seconds and it goes off. Fine.
About this time a BMW Police car comes belting down the road on blues&two's.. Is this for us? After all, we're stood at the side of the road breaking the steering lock on a car, and the alarm's going off..... This could take some explaining. Not for us as it transpired.
Bring around Stu's BX to jump-start this one off, leave it hooked up for a bit, go to try again, and the alarm goes off again. Bloody hell! So the sounder gets beaten to death with a hammer... That's shut that up. Only problem is now that the alarm has gone off, the unit has immobilised the car. Completely. No ignition, no starter, nothing. Shit. Have a look at the alarm to see if it can be reset in any way, and as I poke at it, all the wiring dissolves in a green-copper-corrosion mess. Double shit. Next thought... Can I remove the wiring for the alarm and immobiliser?
At this point I catch more blue lights out of the corner of my eye, and then turn round to see a flourescent van driving very slowly with blue lights on. OK then... this time it's a police van to come and get us is it? Oh no, it's an ambulance.
Trace the cable back from the alarm, and it's connected in at the fuse board, but some clever person (IE a complete penis) has wired it in with about 32000 scotchlocks, and made a complete and utter mess of it. No. Not going to happen. There's no way I can rebuild a BX's fuseboard wiring at the side of the road at 8pm with no lighting, and none of my wiring tools.
So it's still sat there, with most of the dashboard in bits, a new ignition barrell connected but not properly fitted, an alarm in 1000 pieces, and the fuseboard hanging out.
I'm not entirely sure what to do with it now.
