Totally agree with you 'Way2go' !
Not really an issue much simpler than a standard McPherson spring/damper setup.
Way2go wrote:Boxwolf wrote:- but things like rear arm bearings and front struts I would hesitate to touch, less so the struts if I knew what I was doing.
Much easier & faster to change front struts than rear arm bearings!
In fact a very straightforward job.
Boxwolf wrote:For instance I would change a rear wiper motor myself, as would I change front spheres
Boxwolf, if your prepared/able to remove the front spheres
your already half way to changing/swapping the front struts, all that's left is the hydraulic feed pipe to disconnect the bottom strut/leg pinch bolt on the hub assembly and the three suspension plate top nut's to remove and that's basically it !
The sphere tool that you used to change Tourist's front spheres the other week or so, was lent by me via Tim, you obviously found that task NOT to daunting.
The rear spheres can be fairly easy to change (If luck is on your side) but there are a few EXTRA things you need to be aware of prior to attempting that task as you can easy damage the cylinder feed pipes and retaining plate
I always have the engine running so as to keep the pressure on between the cylinders/sub-frame this helps to prevent the cylinder rotating.
I then just 'crack' the thread on the sphere slightly and shut the engine off, then depressurize the hydraulic system prior to the final sphere removal.
This is so as NOT to crack/break the feed pipe, but this does not always work and you do end up having to replace a pipe on the odd occasion, so BEWARE !
BTW do you or Tourist have a
'Hayne's' manual to refer to
If you don't I suggest you buy one between you and read it from cover to cover (I've already suggested this to Tourist in previous thread/postings weeks ago) then I'm sure both of you may have more (or less) confidence in what your taking on with buying/owning a BX after all there getting older not newer with age ! If you do need some good used struts I maybe able to help you out (Send me a PM).
Now when it comes to overhauling the rear radius arm bearings that a different story, I've done this three times (both sides) and I never want to repair another pair of arms ever again !
Check out link below and you will understand why ! The same goes for the four front to rear suspension/brake pipes I've done that to two BX's.
http://www.mars.dti.ne.jp/~ynar/bxorg_a ... /m07e.html
All the best to you and Tourist in finding you perfect
