Citroen Xantia 1.9 td Saloon 96' N only 83000 miles
talbotsteve
Post by talbotsteve »
Due to getting myself a newer BX (YAY!!) I have forsale my blue Xantia turbo diesel saloon. It is low mileage at only 83000 miles, has 4 good tyres, a recent new back box, new rear wheel bearing, 4 months tax and test, i have loads of old bills including one for the cambelt.... £750ono
Has a couple of car park dings, and a dent above the rear door where a roof bar has been over tightened......
Will put up picks later...
talbotsteve
£500????? up for tuesday.....
talbotsteve
Here are pics as promised, there are pics of the small dent on the rear door and of the dent in the roof above the rear passenger side door. It is sat now on my old BX tzd wheels and trims as these have excellent tyres, i do still have the xantia wheels and trims if wanted.
talbotsteve
Up again, £500!!!!! come on folks thats a bargain for an 83,000 96 td :D
Not my thing really mate. But the BX Z trims must add something to it's value surely?
Father Ted
Post by Father Ted »
Aye a few months ago I would have likely taken you up on it, but not just now. Surely it would get £500 on the bay of evil?
Father Ted wrote:Aye a few months ago I would have likely taken you up on it, but not just now. Surely it would get £500 on the bay of evil?
Gotta agree with you on that one Marty, £500 for a low miles disiesel in good nick isnt big money, I think the wheels and trims dont do much for the Xantia., they look too small! Stick the original wheels on, give it a good clean and polish, take them stickers off :wink: and whack it on the bay and you may be surprised.
talbotsteve
Thing with the xantia tyres is.....they are a wee bit on the illegal side :oops: At least these bx tyres are in very good order... :D
talbotsteve wrote:Thing with the xantia tyres is.....they are a wee bit on the illegal side :oops: At least these bx tyres are in very good order... :D
:wink: ahh okidokes, will the xantia trims fit on them wheels? just think you could probably get £30 for those BX ones.
talbotsteve
No one?? not even £400???? might have to sell the bx if i can't get rid of this :cry:
DavidRutherford
BX Digit man!
Post by DavidRutherford »
I know someone who would probably be very interested in this.
Questions:
When was the timing belt/water pump last changed?
How often has it been serviced (oil and filter etc)
How well does it run? Is it an instant start, no smoke in the morning?
How are the rear arm bearings?
What are the expiry dates of the tax and ticket?
... and anything else worth mentioning?
Thanks.
DavidRutherford
BX Digit man!
Also... what size tyres should it be running on? I would indeed want the Xantia wheels, as it ought to be running on the correct tyres.
talbotsteve
DavidRutherford wrote:I know someone who would probably be very interested in this.
Questions:
Thanks.
Hi Cam belt was changed on the 5/03/07 at about 55000 miles.
I changed the oil about 4 months ago but have not used the car in the last month due to having the BX.
It runs and starts very well with no smoke, the starter does sound a little lazy but has only let me down once due to a corroded connector which i replaced, fine ever since.
There are no noises from the rear arm bearings and the wheels are straight and true, nothing leads me to suspect otherwise.
The tax is up at the end of July and the MOT runs out on the 13 of august.
And the tyre sizes should be 185/65/15.
Anything else you need to know please ask,
Cheers Steve
jonathan_dyane
Post by jonathan_dyane »
DavidRutherford wrote:Also... what size tyres should it be running on? I would indeed want the Xantia wheels, as it ought to be running on the correct tyres.
I'm about to break my Xantia, which has 4 wheels with the correct tyres and plenty of tread if you're interested?
jonathan_dyane
...they also have Xantia trims; be more than happy to swap for the BX wheels and trims...
