I'm pretty sure the water is running down the inside of the door seal but not sure where it starts or why. Anyone else has this problem or any ideas of how to solve it? The footwell remains dry when it rains only gets wet when i wash it.
Thanks
That piece of information may have solved my problem, thank you very much! Its so obveous when i look at it now, can see where the seal wasnt against the door and where the tube was pinched between the seal and the door. Just have to wait till the next wash to see if its helped, wont be till after my exams finish although that is very soon!RichardW wrote:And a different one from me...![]()
I had wet fotwell in my first TD. Turned out the concertina tube that carries the wires into the door had rotated and when the door was closed was getting pinched in the door seal, thus bridging it and letting the water in. Rotated it back again and it stopped leaking!
