I have a 150k mile GTi with an autobox. Recently, when the morning is very cold, the take up is sluggish from rest. It soons 'warms up' though, and works fine thereafter. Is there any simple (preferrably) service routine that might cure this - somebody suggested having the filters/fluid checked - someone else said leave well alone unless it gets worse. I tend to subscribe to the latter view. Is this a sign of gearbox wear that is ultimately terminal?
In which case... how difficult is it to replace an auto box?
Autobox query
- Philip Chidlow
- x 25
Autobox query
- ken newbold
Autobox.
Hello. I would not worry, mine is the same given a couple of hundred yards then all is OK. Please check that the ATF is the correct one DEXRON 2 not 3 as this WILL destroy the box as I have found out. See a thread from Alan S (Australia ).
Cheers.
Geoff.
Cheers.
Geoff.
