In for MOT today...
In for MOT today...
My GTi is in for it's test today. Fingers crossed (at least I know the welding that was needed is going pass!)... 8-[
PASSED :D No advisories. Did an ATF change and fitted new exhaust while there... The fluid was in a terrible state, must do another change in the next few thousand and keep doing it every year I think!
Congrats!
If the fluid was REALLY black, smelling and generally filthy, it would be best to change it again after a few hundred miles, or sooner..
The torque converter never completly empties, so it always holds a fair bit of dirge, which gets recycled into the box whilst running, hence even after an oil change the fluid can look black and rancid after minutes.
Post by RxBX »
Philip Chidlow wrote:PASSED :D No advisories.
Nice one Philip !
I always try and basically do a pre-MOT check myself (With the visual/mechanical checks) so as to get no surprises, as you have done with the welding etc; this gives the MOT tester a bit more confidence when testing your car that you look after it by doing proper/preventive maintenance, rather than just relying on an annual MOT to put things right !
All you need now is that low mileage TZD estate to add to you fleet (If I see anything locally or otherwise I'll send you a PM), cheers for now !
docchevron1472 wrote:Congrats!
I am inclined to do that, Chris, yes. Maybe do it before Christmas when the next service is due. Ta!
Well done Phil, Ive got 2 of mine due in the next couple of months, GT should be fine but the St Tropez will need some welding and maybe a couple of arm bearings doing.
ed4ferrets
Yahoo Messenger: [email protected]
Post by ed4ferrets »
Good for another year then Phil, nice one :), mine was due next month and would probably have got through with a new exhaust.
'94 XM 2.1TD Break
'63 Renault Caravelle
cacaolat
Post by cacaolat »
well done ! all the best
Post by ken newbold »
Nice one Philip !
What he said /\ :)
Post by citronut »
Phillip wrote
"must do another change in the next few thousand and keep doing it every year I think!"
why not fit hydraflush for around a 1000 miles, but make sure to get it into all the dead end circuits bleed all the brakes till flushing fluid flows through
citronut wrote:why not fit hydraflush for around a 1000 miles, but make sure to get it into all the dead end circuits bleed all the brakes till flushing fluid flows through
I was referring to the automatic gearbox fluid. But what would happen I wonder if I flushed the gearbox using hydrorinçage? :D
Erm, BANG :shock: I'd wager it would strip itself of any lubricating areas, not to be recommended. I'm sure theres someone out there thats tried it, any of the Dutch nutters know of anyone :wink: :lol:
Philip Chidlow wrote: I was referring to the automatic gearbox fluid. But what would happen I wonder if I flushed the gearbox using hydrorinçage? :D
If you ARE inclined to try it, I think I still have a stripped GTi autobox laying around.. You'll need it!
I certainly am NOT contemplating it. Malcolm misinterpreted my post and I was making light of it :lol: :lol: :lol:
citro-geoff
My Cars: Xantia VSX Estate-146K-1996 (The wifes car)
BX TZD Turbo-317K- Awaiting repair/donor car(broken subframe)
BX TZD Turbo-202K-project car ongoing
BX TZD Turbo-212k-One owner car rescued from being scrapped.
2CV Charleston-101K-One owner car awaiting restoration.
ZX Memphis-185K-Wifes daily driver.
Post by citro-geoff »
Hi Guys,got my TZD mot'd yesterday.Laid the car up in June,and didn't realize the mot was up mid Oct. Now got an mot until Oct 11 next year.Straightened the front and fitted the new bumper yesterday too. Just got to sort a couple of mechanical issues out now,so will soon have it on the road again. Going to move the 16v to my other garage this morning,so the next project is getting nearer. Will probably wait till the new year before I start it. The CX safri will suffice for now as my daily driver!!
1995 ZX Memphis TD Saloon 176k
1997 XANTIA VSX ESTATE-112K(the Wife's!!)
1993 BX TZD Turbo Estate 202k waiting repairs for mot.(Just started to fix it!!)
1985 2CV 100k - waiting full restoration.
