Technical info
Charlotte
Technical info
Um, you probably already all have access through someone, at least, but just so you all know I'm quite happy to access the Citroen online database for any of you (you have to be a trader to get anything more than glovebox manuals), to get schematics, part numbers and all the really nerdy trim info and codes...
Also Autodata!
So admin at medwaycitroen dot com if this could help any of you.
Also Autodata!
Bride of Stinkwheel
http://weaselsemark.carbonmade.com
Citroen BX St Tropez
Still not over H592 AGW "Hugo" TZD Turbo
BX 16v Ph2 - XPO - x 103
Mike E (uk)
I have the exact same job on my BX too, scheduled for this weekend.
I also expect to have to replace both the pipes that fit onto the rear struts as I doubt they will come off complete.
parts No for both sides appreciated.
thanx
Mike
thanx
Mike
jonathan_dyane
Mat,
For whatever reason, I am still able to access Citroen Service (made up business name and address, real VAT number off a reciept I had lying around) and can confirm that is the correct part number.
i to can still access service citroeni do run my own repair shop but not VAT registerd, and did not enter any VAT reg No.'s,
i find when checking parts/price's when you select the opption to get a price, the firt screen comes up with a new registration form insted of the price box/page,
then if you ignor this and click bascket again the price comes up,
Thanks Jonathan, there are a few for sale on ebay here but I thought I'd better check first!
cauchoiskev
DLM
- Our Trim Guru
In my BX parts pile I've got what looks like an 8v GTi corrugated rubber air tube with two metal inserts. A sticky label on one of the metal inserts appears to show the part number 96631794.
Someone has suggested it may not be the standard GTi part - can anyone confirm what it is, from the part number or otherwise, please?
- x 113
I don't recognise the p/no but what it looks like is the Mk1 GTi flowmeter intake. Also the TZi and 16v (I think) are similar, they have the Motronic 1.3 system.
It is deffo not for the later GTi with the Motronic 3.1.
jonathan_dyane
Mike, sorry I did not spot your request earlier, or I'd have got the number for the other side too...
DLM, I don't know how to make citroenservice search for a part number, but can confirm that the number does not match 8 valve 1.9 injection...
DLM
- Our Trim Guru
Sounds like I should have taken a peek under the bonnet of the E-reg Gti at Stratford... many thanks for the replies. Somebody did suggest it was for a 4x4 GTi as apparently there's a different setup on these. I may ask the local mechanic who's done a lot of work on a GTi 4x4 for one of his customers.
- x 113
i had problems loging onto my pug service box acount, it said my login details were wrong,
so i tried the forgot my details and got an email with new login codes, they did not work so i sent an email to the technical support desk, who it turns out are in Germany but after a coouple of emails to and frow they sent a request to pug coventry/UK who contacted me,
very helpfull,freindly and sorted my login out,
i dont now about service citroen but with the pug service box site you can also register as a jo public, even though im registerd as trade the same as my service citroen acount,
so Vanny it might be worth you contacting the tecnical assistance team,
they are one and the same as the pug lot in Coventry
pinley house 2
sunbeam way
coventry
CV3 1ND
EMAIL
[email protected]
pinley house 2
sunbeam way
coventry
CV3 1ND
[email protected]
